Activate camera-based speed limit display Audi A6 4G
jobeagle
Post24-12-2017, 15:45    Subject: Activate camera-based speed limit display Audi A6 4G Quote
Hello everyone,
I'm trying to activate the speed limit display feature on my A6 facelift (using VCDS version RKS 17.8.1).
Here's what I did:
STG 17 Adjustment Channel "modified". "Traffic sign recognition" enabled.
STG 8E: Byte 2, bit 0 set (B8 -> B9).
Adaptation channels for "valid supplementary signs," "no overtaking" signs, and "end of speed limit" signs. "Welcome" activated.
STG 5F adaptation channel enabled for "BAP-traffic_sign_recog._0x21", "menu_display_road_sign_identification", and "menu_display_road_sign_identification_over_threshold_high".
Then I tried to activate the hidden menu (where VZA (Off) should be disabled) using:
STG 5F, adjust channel 06 to 1.
- I couldn't find that, though...
Okay, so here's the situation: I can activate the speed limit display for both the car and the assistant, and the new menu option is also present in the instrument cluster. However, I only receive the following message:
"Speed limit display outside of operational area."
Is there anything I'm missing? I read something about a "label file"...
(Unfortunately, I'm only an IT specialist and not a car mechanic icon_smile.gif).
Perhaps someone has already managed to do this with VCDS?
hadez16
Avatar-hadez16
Post04-01-2018, 20:12    Subject: Activate camera-based speed limit display Audi A6 4G Quote
To my knowledge, you need to flash the image processor to enable the variable zoom encoder (VZE) on the 4G device.
A little bit of superficial knowledge.
Therefore, you're essentially out of the running with VCDS.
jobeagle
Post13-01-2018, 11:39    Subject: Activate camera-based speed limit display Audi A6 4G Quote
Okay, thanks. I'll just put that topic aside for now.
naniska
Post11-07-2022, 0:36    Subject: Activate camera-based speed limit display Audi A6 4G Quote
jobeagle wrote:
Okay, thank you, then I'll put the topic aside for now.
Have you found a solution to it? I'm having the same problem myself.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Activate GRA in Audi A2 Diesel Engine Technology
No new posts GRA einbau/ aktivieren beim Audi 80 TDI Bj 93 Diesel Engine Technology
No new posts Cruise Control Installation: Audi 80 TDI 90PS Diesel Engine Technology
No new posts GRA aktivieren Diesel Engine Technology
