Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
trubenba
Post13-08-2022, 17:43    Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Quote
Hello, I'm having the following problem: The air conditioning stopped working. The compressor was replaced and recharged. The compressor is working, but the interior isn't getting cold. When I read the error codes, the following message appears: "Temperature sensor, evaporator, defective" and the error cannot be cleared. Can anyone tell me where this temperature sensor is located and how to replace it?
Passat 2,8 APD 4 Motion
Translated on 03-07-2026, 16:21.
dieselschrauber likes this.
Post13-08-2022, 18:39    Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Quote
Please provide the exact error codes and descriptions from the VCDS scan.
There's a sensor that you can see when you remove the pollen filter and look up towards the blower motor. It's accessed from inside the car; you need to remove the panel underneath the glove compartment and reach up. It requires a quarter turn and then you can pull it out, but it's quite fiddly.
Translated on 03-07-2026, 16:22.
trubenba
Post14-08-2022, 8:08    Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Quote
That is the error code: 332, Thermistor, Evaporator.
Translated on 03-07-2026, 16:23.
Post14-08-2022, 8:44    Subject: Re: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Quote
trubenba wrote:
This is the error code: 332. It indicates a problem with the temperature sensor in the evaporator.
Okay, I didn't grow up with a silver spoon in my mouth. If something broke down for me, I knew that either I had to fix it myself, or the thing was junk, with all the consequences that entailed. Broken car -> no car, for example.
And when I asked someone for help, I was very, very happy to receive a sensible answer.
That's why I've always tried to express myself politely and clearly, and then to express my appreciation for the help I received.
We are in the year 2022, and we no longer need to carve things into stone tablets; almost everyone possesses a brain prosthesis, which we call a cell phone.
Almost all mobile phones have the ability to take pictures, for example, of error messages.
Translated on 03-07-2026, 16:24.
trubenba
Post14-08-2022, 11:14    Subject: Passat 3BG air conditioning system Quote
Okay, thank you again to everyone who put in the effort to troubleshoot the issue with the error code 332, which relates to the evaporator temperature sensor. I found the error.
You wouldn't believe it, but it's true. It was due to the control panel of the air conditioning system. I once replaced it because the lighting was malfunctioning. Somewhere, I read that there's a difference in the programming or something like that between the two suppliers, Hella and VDO. I seem to remember that. So, I swapped the control panel back to the old one. The self-diagnosis test for the climate control showed no errors, and the climate control function is working properly again.
Translated on 03-07-2026, 16:26.
Post15-08-2022, 7:23    Subject: Temperature sensor, evaporator, Passat 3BG 4Motion, 2.8L Quote
Okay, so the result is: You replaced the control panel of the air conditioning system with an incompatible one, which caused an error. Okay.
Translated on 03-07-2026, 16:27.
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel sensor Passat 3B Syncro/4Motion Transmission, Chassis, Body & Interior
No new posts VW Passat 4Motion: AVF Engine Idler Pulley Diesel Engine Technology
No new posts Passat 3B 4Motion: Wobbly, Breaks Loose When Braking Transmission, Chassis, Body & Interior
No new posts Climate Change: Where is the Vaporizer? Transmission, Chassis, Body & Interior
