Audi A6 C5 Allroad transmission conversion: from Multitronic automatic to manual
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Tanta007
Post13-12-2022, 21:37    Subject: Audi A6 C5 Allroad transmission conversion: from Multitronic automatic to manual Quote
Hello everyone, here's a problem:
The conversion from automatic to manual transmission is already complete, but I'm stuck because I have two errors stored in the brake control unit: [Error 1] and [Error 2].
Data bus, drive system: No communication with the transmission control unit.
Control unit incorrectly programmed.
The engine control unit cannot be reprogrammed, even though the other control units and vehicle configuration data are correctly coded, and the drive system is already properly configured.
Regarding the car: Audi A6 C5 Allroad, year 2002, 2.7 bi-turbo.
Karma: +643 / -0   Thank you, like it!
dieselschrauber and Tanta007 likes this.
Post14-12-2022, 8:18    Subject: Audi A6 C5 Allroad transmission conversion: from Multitronic automatic to manual Quote
Hi.
Then you'll probably have to find a suitable engine control unit (ECU) from a manual transmission version... assuming that version even existed.
Tanta007
Post14-12-2022, 8:37    Subject: Audi A6 C5 Allroad transmission conversion: from Multitronic automatic to manual Quote
Thank you for the quick response. Yes, it already existed as a manual switch.
Post14-12-2022, 17:37    Subject: Audi A6 C5 Allroad transmission conversion: from Multitronic automatic to manual Quote
I also have a control unit in my A4 Quattro that cannot be reprogrammed, for whatever reason.
No new posts Document A4 8E Diesel with 5-speed manual transmission: O... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Allroad Luftfahrwerk - keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log 3, 8, 11 Audi A6 2.5 TDI BDG, Manual Transmission (Or... Upload
No new posts Audi A5 B8 2,7 TDI Multitronic Probleme Transmission, Chassis, Body & Interior
No new posts Reverse gear problem Audi A4 8D 1.8T Multitronic, first r... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Log´s 3,8,11 Audi A6 Allroad 2.5 TDI Tip. 2005 BAU Upload
