My sister-in-law's Seat Ibiza is having problems.
This error keeps occurring sporadically and without any apparent trigger.
7380 - Charge pressure sensor (G31).
P0236 00 [036] - implausible signal.
She took her car to a workshop weeks ago, where they replaced the entire EGR unit and the turbocharger pressure sensor.
I cannot say what error was present at that time.
The wiring from the sensor to the MSG is continuous and does not cause any measurable resistance.
The new Bosch sensor I installed immediately triggered a stored error code after installation.
Tuesday, November 16, 2021, 7:00:23 PM: 23565
VCDS - A Windows-based VAG/VAS emulator that runs on Windows 10 x64.
VCDS version: DRV 20.12.0.3
Data as of: 20210211 DS322.1
www.Ross-Tech.de
Vehicle Identification Number (VIN): VSSZZZ6JZBR191609 License Plate: ANIKA
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Address 01: Engine Control Module
Label file: DRV\03L-906-023-CAY.clb
Control unit part number: 03L 906 023 LD. Hardware version: 03L 906 023 Q.
Component and/or version: R4 1.6L TDI H33 9978.
Encoding: 00114016002400080000
Operating number: WSC 131071 1023 2097151.
ASAM Dataset: EV_ECM16TDI02103L906023LD 003012 (SE25)
ROD: EV_ECM16TDI02103L906023LL.rod
text
VCID: 73E3B198DAE9251C0D-8026
"One error found:"
P0236 00 [032] - Implausible signal.
Occasionally - unconfirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 2.
Date: 2000.00.00
Time: 00:00:00
Motor speed: 0.00 rpm.
Normalized load value: 0.0%
Vehicle speed: 255 km/h
Coolant temperature: 42 °C.
Intake air temperature: 5 °C
Ambient air pressure: 1010 millibars.
Voltage at terminal 30: 12.424 V.
Lost learning counter via OBD: 40.
Boost pressure: Actual value - MAP (Manifold Absolute Pressure): 200.00 hPa.
Boost pressure: Setpoint - MAP_SP_MMV: 200.00 hPa.
Ambient air pressure: 101 kPa absolute.
Particle filter: Differential pressure - DPF: 6.47 hPa.
Readiness: 0 0 0 0 0
Saturday, November 20, 2021, 3:22:50 PM: 0.23565
www.Ross-Tech.de
Part and/or version: R4 1.6L TDI H33 9978.
text
Two error codes found:
Error priority: 2
Error frequency: 2.
Mileage: 170,917 km
Date: 2119.14.23
Time: 00:06:31
Coolant temperature: 16 °C
Intake air temperature: 7 °C
Ambient air pressure: 1000 millibars.
Voltage at terminal 30: 11.181 V.
Ambient air pressure: 100 kPa absolute.
Particle filter: Differential pressure - DPF: 0.00 hPa.
7382 - Charge pressure sensor (G31).
P0236 00 [096] - implausible signal.
Error priority: 2
Error frequency: 3.
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 22 °C.
Intake air temperature: 6 °C
Voltage at terminal 30: 12.311 V.
Boost pressure: Actual value - MAP (Manifold Absolute Pressure): 1129.50 hPa.
Boost pressure: Target value - MAP_SP_MMV: 1129.50 hPa.
Thank you in advance for your ideas and help.
