Turbocharger Boost Control Adjustment After Replacement
Marpi24
Post20-11-2022, 13:50    Subject: Turbocharger Boost Control Adjustment After Replacement Quote
Okay, here's the translation:
"I replaced the VTG turbocharger pressure control (vacuum valve) on my Skoda Octavia 2.0 TDI with a CFHC engine and now need to adjust it precisely. Simply copying the settings from the old pressure control unit won't work because that valve is completely defective; explaining the reason would take too long. I've heard about measuring blocks, but they are no longer displayed on Skoda vehicles, only the "relevant" measured values. Can I use VCDS to adjust any values, or can I turn something on the adjustment rod to achieve the correct readings?"
However, one would also need to know those values, and I haven't found anything about "erWin."
Translated on 15-08-2026, 20:45.
Post20-11-2022, 19:43    Subject: Turbocharger Boost Control Adjustment After Replacement Translating...
[Translating...]
Autoscan?
Marpi24
Post20-11-2022, 19:55    Subject: Turbocharger Boost Control Adjustment After Replacement Quote
Saturday, November 19, 2022, 4:09:01 PM: 15077
VCDS – a VAG/VAS emulator based on Windows – runs on Windows 11 x64.
VCDS version: DRV 22.3.1.7
Data as of: 20220523 DS338.0
Vehicle Identification Number (VIN): TMBHE61Z0Cxxxxxxx License plate: [Insert license plate number here]
Vehicle type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 69 72
Vehicle Identification Number (VIN): TMBHE61Z0Cxxxxxxx Mileage: 275,610 km
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate control/heating unit - Status: OK 0000
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: Error 0010.
42-Door Electric Driver -- Status: OK 0000
Steering assist - Status: OK 0000.
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module (J623-CFHC)
Label file: .DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 CT, HW: 03L 906 018 BR.
Part: R4 2.0L TDI H24 9977
Revision: 42H24--- Serial Number: CVN: 2D771E93
Encoding: 001D0012042400080000
Operating number: WSC 58441 107 00000
ASAM Dataset: EV_ECM20TDI01103L906018CT 003006
ROD: EV_ECM20TDI01103L906018CT.rod
VCID: 7EF43827E1CD907FBE-802A
VINID: 91D49854606A0130811C31C020DB65D4F7
No error codes found.
Readiness: 0 0 0 0 1 0
Address 02: Transmission Label file: DRV\02E-927-770.clb
Part number SW: 02E 300 057 P, HW: 02E 927 770 AL.
Component: GSG DSG AG6, part number 512 3103.
Revision: 05551213 Serial Number: 00001203091161
Encoding: 0000020
Operating number: WSC 73430 790 00090
VCID: 2644304791DDE8BF96-8072
Address 03: Brake Electronics (J104)
Label file: .DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 BJ. Part number HW: 1K0 907 379 BJ.
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Encoding: 113B401C092900FD881202E490210042350000
VCID: 7BF23133FADF855799-802E
Address 08: Climate Control/Heating (J255)
Label file: | DRV\5K0-907-044.clb
Part number SW: 3T0 907 044 BL, HW: 3T0 907 044 BL.
Component: Climatronic H18 0506
Revision: 00001007
Encoding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 7DF63F2BECCB8B67A7-8028
Address 09: Central Electronics (J519)
Label file: .DRV\1K0-937-08x-09.clb
Part number SW: 1K0 937 087 Q. Hardware part number: 1K0 937 087 Q.
Part number: BCM PQ35 H 110 0651.
Revision: 00110 AC
Encoding: 40000AB8E00508C040080080510091E4437000AE726D85605C8540000040
VCID: 3F8A8523AE475977F5-806A
Subsystem 1 - Part number: 1Z1 955 119 D
Label file: DRV\1KX-955-119.CLB
Part number: Wiper 18031 26 0601.
Encoding: 00D7B7
Subsystem 2 - Part number: 1K0 955 559 AH
Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 220312 05 54 0403
Encoding: 0730ED
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 T HW: 1K0 909 605 T
Part number: Q6 AIRBAG VW8, 020 2300.
Revision: 05020000 Serial Number: 0038PD2VV7B2
Encoding: 0020790
VCID: 3D76FF2B644B4B67E7-8068
Subsystem 1 - Serial number: 6332MSME6C434A6BR.
Subsystem 2 - Serial number: 6342MSME6B53773CQ
Subsystem 3 - Serial number: 6351HSME2B64347BF.
Subsystem 4 - Serial number: 6361HSME2B642E70E.
Address 16: Steering wheel electronics (J527)
Label file: | DRV\5K0-953-569.clb
Part number SW: 5K0 953 521 AT, HW: 5K0 953 569 B.
Component: STEERING MODULE 014 0140
Revision: FF010040 Serial Number: 20120327800463
Encoding: 189A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
FILE: EV_SMLSNGVOLWS.rod
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3T0 959 537 A, HW: 3T0 959 537 A, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-URO H07 0012
Encoding: 830000
Address 17: Control panel module (J285)
Label file: | DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 1Z0 920 843 S, HW: 1Z0 920 843 S.
Component: COMBINATION UNIT H05 0608
Serial number: 00000000000000
Encoding: 110E01
Operating number: WSC 73430 031 00090
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 48989EFFF3891ECF44-801C
Address 19: Diagnostic interface (J533)
Label file: .DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 M, HW: 1K0 907 951.
Component: J533 Gateway H42 1623.
Revision: H42 Serial Number: 190312F1002201
Encoding: 352302
VCID: 3A7CF437B5657C5FC2-806E
Address 25: Immobilizer (J334)
Label file: | DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234, HW: 5K0 953 234.
Component: IMMO H05 0608
Encoding: 000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADC04778D450CDF72-803E
Address 37: Navigation (J794)
Label file: | DRV\1K0-035-27x-37.clb
Part number SW: 3T0 035 192 F, HW: 3T0 035 192 F.
Part number: RNS315-EU H36 0263.
Serial number: SKZAZ2M9251876
Encoding: 000004110401000000000301
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 316ED31B6013BF0773-8064
Storage devices:
Subsystem 1 - Part number: 3AA 919 866.
Component: EUR_W_0038 0038
"One error found:"
1048642 - Control unit defective.
B2000 42 [009] - General memory error.
[New feature! Extended UDS error code information is supported only by the current generation of hardware.]
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 4.
Error frequency: 1.
Mileage: 262493 km
Date: 2022.04.03
Time: 13:10:48
Address 42: Door electric driver. Label file: .DRV\1K0-959-701-MIN3.clb
Part number SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Door seal 009 2119
Encoding: 0000244
VCID: 48989EFF3B891ECF44-801C
Address 44: Steering Assist
Label file: DRV\1K0-909-14x-GEN3.clb
Part number: 1K0 909 144 P
Component: EPS_ZFLS, Size 70 3305
Revision: 00H22000
VCID: 377AED03467761373D-8062
Address 52: Power door lock, front passenger side. Label file: .DRV\1K0-959-702-MIN3.clb
Part number SW: 1T0 959 702 R. Hardware: 1T0 959 702 R.
Encoding: 0000244
VCID: 479A9DC3369711B74D-8012
Address 55: Headlight range adjustment. Label file: DRV\5M0-907-357-V2.clb
Part number SW: 5M0 907 357 C. Hardware: 5M0 907 357 C.
Component: AFS Control Unit 0148
Revision: 00H04000 Serial Number:
Encoding: 1507354
VCID: 3460DA0F57018A2F18-8060
Subsystem 1 - Part number: 7L6 941 329 B
Label file: 3D0-941-329.CLB
Component: AFS-List Module l 0005
Encoding: 00000023
Subsystem 2 - Part number: 7L6 941 329 B
Component: AFS-List Module r 0005.
Encoding: 00000023
Address 62: Door electrics, left and right. Label file: .DRV\1K0-959-703-GEN3.clb
Part number SW: 5K0 959 703 A, Part number HW: 5K0 959 703 A.
Component: Door Seal 007 2101
Encoding: 0000144
Operating number: WSC 73430 790 1012570
VCID: 326CDC17AD15841F0A-8066
Address 69: Trailer (J345) Label file: .DRV\1K0-907-383-V2.clb
Part number SW: 1K0 907 383 F. Hardware: 1K0 907 383 F.
Component: Trailer H09 0100
Revision: 3A001001 Serial Number: 00008030096516
Encoding: 410D000100000000
VCID: 3068D61F6319B60F7C-8064
Address 72: Door electric strike, high, right. Label file: .DRV\1K0-959-704-GEN3.clb
Part number SW: 5K0 959 704 A, HW: 5K0 959 704 A.
Encoding: 0000144
VCID: 3362D913520F8D1701-8066
End----------------------------(Duration: 02:24)-----------------------------
Translated on 15-08-2026, 21:22.
Post20-11-2022, 20:55    Subject: Turbocharger Boost Control Adjustment After Replacement Quote
The easiest way is to use the position of the lock nut on the adjustment rod as a reference point.
I would also recommend that, because there are many different types of chargers available, some with and some without a locking mechanism.
If there is no physical connection, adjusting the settings based on measured values can be risky and may damage the charger.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Error After Wheel Bearing Replacement Diesel Engine Technology
No new posts Engine Control Unit Failure After Injector Replacement On-Board Diagnostics (OBD)
No new posts TDI CAYE: LMM Error After Replacement - Low Power Diesel Engine Technology
No new posts T5 GP BCM Coding: Error After Replacement? On-Board Diagnostics (OBD)
