Golf 6 Variant 1.6 TDI Battery Registration/Calibration
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +643 / -0   Thank you, like it!
Post04-12-2022, 17:42    Subject: Golf 6 Variant 1.6 TDI Battery Registration/Calibration Quote
Hi.
I only buy demonstrator cars from car recycling centers, so I'm not really knowledgeable about the subject.
A friend of mine (over 70) from the village inherited this 2010 Golf from her husband. Earlier, the battery was weak while she was at the cemetery, so I gave it a jump start using a power bank, and I've now connected the car and battery to my charger.
If it doesn't work again and needs to be replaced, I'm unfortunately not sure whether it will need to be programmed to the vehicle's onboard network control unit, or if a simple replacement will suffice.
It is not an original battery that has been installed.
Stand there like an idiot.
Thank you very much.
Post04-12-2022, 18:52    Subject: Golf 6 Variant 1.6 TDI Battery Registration/Calibration Quote
You can take the data from the old battery and increment the serial number if the new battery is not the intended one.
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
dieselschrauber likes this.
Post04-12-2022, 20:35    Subject: Golf 6 Variant 1.6 TDI Battery Registration/Calibration Quote
To the best of my knowledge, for vehicles of this age, a new battery only needs to be registered if the vehicle is equipped with a start/stop function.
An AGM battery is often installed there as well. It should then be registered within the Battery Energy Management (BEM) system using the battery's unique BEM code.
Why should I?
The advantage is that the functionality of all systems is immediately available and does not require a "learning phase" first.
For a non-registered battery (or a branded battery without a BEM code), the BEM system periodically monitors and logs any activities that put a strain on the battery.
- so-called trigger events such as starts, cold starts, battery voltage, etc. - the necessary information and then ensures the full functionality of all available systems.
If necessary, as Rainer mentioned, you can simply increment the serial number. As far as I know, it's also possible to use any 10-digit number.
Best regards, Richard.
Polo V 1,6 Tdi (CAY)
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2002, Batterie entladen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Batterie (Akkumulator): Tipps zu Check und Wartung Technical Articles
No new posts Mercedes-Benz Sprinter 907 BMS battery pairing Electrical Systems, Vehicle Electronics, Multimedia
No new posts Do you need to register the battery after replacing it in... On-Board Diagnostics (OBD)
No new posts Batterie Golf 3 TDI Diesel Engine Technology
No new posts Golf 4 engine control unit programming On-Board Diagnostics (OBD)
