Glow Plug Light Flashing: DPF & Engine Error Codes
Jock1962
2008 Audi A3
Post02-01-2023, 19:48    Subject: Glow Plug Light Flashing: DPF & Engine Error Codes Quote
Hello, I'm having a problem that seems similar to something that was posted here before. It's an Audi A3, 2.0 TDI, manufactured in January 2008, with part number 0588; AAV.
It's my son's car. According to his description, the DPF (Diesel Particulate Filter) light has been coming on more frequently lately, but it could be resolved with a regeneration cycle. On his last trip, both the DPF light and the engine check light came on, and the glow plug indicator is blinking. The car is now in limp mode.
Today, I read the error memory and found the following two errors stored:
08194 Particle filter, bank 1, efficiency below threshold.
00579 Electromagnetic switch: ON, statically blocked or without voltage.
The error 00579 could be cleared and has not reappeared since.
The vehicle is still malfunctioning, and the warning lights are on.
I'm now wondering where I can start troubleshooting, as a regeneration of the DPF couldn't be initiated today through a regeneration cycle.
"I read the data using a Foxwell NT 510 that I bought years ago when I still owned an Audi. I'll need to take a closer look at it tomorrow."
It would be great if someone could give me a little help with that.
 File size:  1.79 MB
 Viewed:  2668 times
Translated on 13-08-2026, 1:51.
Martininii
Karma: +24 / -1   Thank you, like it!
dieselschrauber, Rüdi and Herbert likes this.
Post02-01-2023, 20:52    Subject: Glow Plug Light Flashing: DPF & Engine Error Codes Quote
Can this device read the level of soot in the DPF (Diesel Particulate Filter)?
I would recommend purchasing a support ticket from the store, otherwise the assistance you receive here will likely be very limited. Alternatively, you could purchase an interface...
I can tell you from my own experience that the support here with premium service is really excellent in the long run, and it's better than anywhere else! icon_smile.gif
Caddy 3 mit BLS Motor, 105PS, DPF (0603/AGB)
Renault Laguna 2 mit F9Q Motor, 107PS/120PS (3004/158)
Translated on 13-08-2026, 1:53.
Jock1962
2008 Audi A3
Post03-01-2023, 9:10    Subject: Glow Plug Light Flashing: DPF & Engine Error Codes Quote
Good morning, thank you for your quick reply.
I think the device can do that. I'll try it again today. If I remember correctly, I saw those values yesterday when I was looking through the data.
I'm just surprised that there aren't any other error codes stored in the system memory.
How does the support ticket system work, and what are the costs involved?
Translated on 13-08-2026, 1:54.
Post03-01-2023, 9:51    Subject: Glow Plug Light Flashing: DPF & Engine Error Codes Translating...
[Translating...]
https://shop.dieselschrauber.org/en/obd-support-key-p-112.php
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Climatronic display blinking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Glow plug light flashing, DPF and engine check lights on! Diesel Engine Technology
No new posts Glow plug light flashing - ASZ TDI PD Diesel Engine Technology
No new posts Audi A6 2.5 TDI, Preheat lamp flashing (AAT) On-Board Diagnostics (OBD)
No new posts Power Cord/Glow Plug Flashing: Troubleshooting Diesel Engine Technology
