Error light, indication of defective lamps (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Steffen G and E30_V8 likes this.
Post19-07-2023, 19:47    Subject: Error light, indication of defective lamps Quote
Current vehicles have a warning light to indicate defective bulbs.
In the example, a faulty daytime running light on the right side (diagnosed with VCDS), which caused the aforementioned error message.
Address 09: Central Electrical (J519) Label file: .DRV\7E0-937-BCM-V1.clb
Part number SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 024181189
Encoding: 62A8393A4A21201201200F806CAB8ED4D29069C960CD6970330400B30800
Operating number: WSC 02762 534 100478
VCID: AB164661CAF65ECBCE-80FE
Subsystem 1 - Part number: 5K7 955 559 C Label file: DRV\5K7-955-559.CLB
Component: RLS 300118 04 47 0106
Encoding: 0228DD
Subsystem 2 - Part number SW: 7E0 959 801 M HW: 7E0 959 801 M
Component: J386__TSG_FT 004 0653
Serial number: KU0KU017011880173811
Encoding: 0400A0
Subsystem 3 - Part number SW: 7E0 959 802 M HW: 7E0 959 802 M
Component: J3 87__TSG_BT 004 0653
Serial number: KU0KU023011880230577
Encoding: 1400A0
1 error found:
02746 - Daytime running light right
010 - Interruption/Short circuit to positive
Environmental conditions:
Error status: 01101010
Error priority: 3
Error frequency: 254
Lost counter: 21
Mileage: 125956 km
Time: 0
Date: 2023.05.29
Time: 12:57:37
A diagnostic system like VCDS is helpful here to determine which light is responsible for the error message, because not always does the corresponding indicator light have a permanent failure, and not always are all the lights monitored.
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Ratings - Error light, indication of defective lamps
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Resetting the service interval display on a Volkswagen Go... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding the service interval display on Golf III Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 brake pad warning light Transmission, Chassis, Body & Interior
No new posts H7 Bulb Lifespan: How Long Do They Last? Diesel Engine Technology
No new posts Xenon Headlights: Are They Blinding? Diesel Engine Technology
No new posts VCDS/VAG-COM: Adjusting Xenon Headlights Diesel Engine Technology
