Read WfS login data from Passat 3C B6
Cartec
Post15-05-2023, 11:49    Subject: Read WfS login data from Passat 3C B6 Quote
Hello.
"I'm having a problem with my Passat (year 2007, engine code: BMT). It has lost the key coding for the immobilizer system."
To re-initialize the device via VCDS, I need the WfS login code.
I tried to read this data from the instrument cluster using a VAG EEPROM programmer, but without success ("No EDC found").
Is there another option available?
The code printed on the plastic tag that came with the car when you bought it from VW doesn't help either, does it?
Best regards.
chli1976
dieselschrauber likes this.
Post15-05-2023, 17:47    Subject: Read WfS login data from Passat 3C B6 Quote
The login process is located in the comfort control unit, but you will also need the central control unit, as simply logging in will not be sufficient.
VCDS
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. VAG-COM: Read Login/Immobilizer IDs - How To? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. VAS 5051 Login: Passat AKN Diagnostics Diesel Engine Technology
No new posts Passat 3B Airbag Error Deletion Login On-Board Diagnostics (OBD)
No new posts OBD Scan Passat 3B: Read Error Codes On-Board Diagnostics (OBD)
