Timing Belt Tips for 1.9 TDI (1997-2000) (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
dieselschrauber Post16-06-2003, 9:45
TDI Timing belt tip.
for the 1.9L engine with a distributor injection pump
The timing belt replacement interval for some...
"1.9L TDI engines produced before the year 2000 were, for safety reasons,..."
reduced from 90,000 km to 60,000 km.
In later model years, this reduction was reversed.
Furthermore: At VW/Audi, starting with the model year...
2000 (identification letter Y), a more 'stable' timing belt was probably installed.
This has the VAG part number 038 109 119 D.
[Edit Admin]depending on the engine code and engine number: 038 109 119 M[/Edit Admin]
Therefore, there should be no objection to also using it in cases where...
For older vehicles, the interval can be set to 90,000 km if they meet this requirement.
Belts are already installed.
The part number can be found on the (original).
Belts as well as the invoice for the last timing belt replacement.
It is important to check the timing belt.
And don't forget the tensioning rollers/guide rollers, as these are often worn out.
Improper storage can immediately damage the timing belt and lead to complete engine failure.
Anyone who wants to be on the safe side should replace the tensioner pulley along with the timing belt.
Information from the timing belt manufacturer Continental regarding this topic, including replacement intervals and installation tips.
All information is provided without guarantee and to the best of our knowledge!
Translated on 02-08-2026, 17:45.
Ratings - Timing Belt Tips for 1.9 TDI (1997-2000)
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
No new posts Airbag sensor issues, 1997 model, type 1H1 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B5 1997: Faulty WFS - Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Ignition Switch Audi A4 (1997) Stuck Transmission, Chassis, Body & Interior
No new posts 1.9L TDI: Tech Changes 1997-99? Diesel Engine Technology
No new posts Tuning Box for Galaxy 1997 Diesel Engine Technology
