sardu
27-03-2023, 19:19 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
My car is jerking when stationary and consuming more fuel than usual. I suspect a faulty injector. There are no fault codes in the memory, but I have read out the following measurements. Does this mean that the injector for cylinder 4 is faulty?
Injection timing deviation cylinder 1 -8 µs
Injection timing deviation cylinder 2 -6 to -13 µs fluctuating
Injection timing deviation cylinder 3 3 µs
Injection timing deviation cylinder 4 19 µs
chli1976 Profi-Schrauber
27-03-2023, 19:39 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
It needs to include the measurement value for injection quantity deviation or something similar, which are displayed in mg/stroke, please post those.
VCDS
sardu
27-03-2023, 19:51 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
I found this, but I can't find any information about fuel injection volume differences per cylinder… It seems like it's not available. I have also put everything together in a video: [Videos can be uploaded here!]
IDEO... Average Injection Volume
IDEO... Main Injection: Target Value
IDE1
Injection 2: Target Quantity
IDE1... Injection 1: Target Value
IDE1... Direct Injection 3: Target Quantity
5 mg/stroke
2.93 mg/stroke
0.00 mg/stroke
0.00 mg/stroke
0.00 mg/stroke
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
27-03-2023, 20:33 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
Please upload your video in this topic to avoid link leaching.
Profile PM WWW Garage |
Herbert Profi-Schrauber
dieselschrauber likes this. |
27-03-2023, 22:07 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
chli1976 wrote: | | It needs to show the measurement value for injection quantity deviation or something similar, which are displayed in mg/stroke, please post those |
Refers to the 1.6 TDI gear shift timing adjustment.
sardu
31-03-2023, 17:31 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
Unfortunately, I was unable to find any extended measurement values in the vcds data. Do you have another idea?
| Description: |
| File size: |
8.39 KB |
| Viewed: |
430 times |
31-03-2023, 17:50 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
I'm unfortunately unable to open the image.
You need to relate the injection duration, the average injection amount, and the injection timing deviations from your first post to each other, then you will have the injection amount deviation per cylinder.
The 1.6 TDI STG only provides information about injection timing deviations, not quantity correction values (I mistakenly wrote "shift time correction" above).
The injection duration is around 100 µs at idle for my 2.0 TDI. That would be acceptable for these deviations in my engine.
sardu
31-03-2023, 18:15 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
Ok, then the only option is to go to the workshop.
31-03-2023, 19:19 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
Why no diagnosis, no check of timing, no check of return flow?
The workshop would initially only be limited and not applicable for certain tasks, for example, for checking the compression.
sardu
31-03-2023, 19:50 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
I am not a kfzler, so I will initially focus on VCDS diagnostics. Tax periods would be excluded as they are only temporary and then also okay again.
31-03-2023, 21:43 Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 |
Time for an auto-scan ...
