Audi A6 2.5 TDI AKE Quattro fuel injection quantity
Luk72
Post02-04-2023, 9:00    Subject: Audi A6 2.5 TDI AKE Quattro fuel injection quantity Quote
Good morning.
I hope someone might be able to give me some advice.
It's about a 2.5-liter AKE engine from an Audi A6 4B.
The engine is already injecting 12-14 mg of fuel at idle.
If I keep the engine speed too low, it runs very rough and noticeably rich.
"Accordingly, it smokes excessively and rattles at the bottom."
Under load and above 2500 RPM, it runs smoothly.
I've noticed that the actual and target values for the start of the injection process are not aligning.
The higher the frequency, the greater the differences in values.
Unfortunately, I'm running out of ideas, and the only option left for me is to submit it.
I am grateful for any help. The problem appeared suddenly, overnight.
Best regards, Lukas.
Translated on 22-07-2026, 11:53.
Post02-04-2023, 9:21    Subject: Audi A6 2.5 TDI AKE Quattro fuel injection quantity Quote
Hi.
For more in-depth questions regarding diagnosis, please use the support ticket system. This service is exclusively available to customers and is provided free of charge.
Translated on 22-07-2026, 11:55.
Karma: +643 / -0   Thank you, like it!
Post02-04-2023, 10:49    Subject: Audi A6 2.5 TDI AKE Quattro fuel injection quantity Quote
Hi there.
Can problems with the camshaft be completely ruled out?
Greetings.
Luk72
Post02-04-2023, 11:03    Subject: Audi A6 2.5 TDI AKE Quattro fuel injection quantity Quote
The engine was completely disassembled. I measured the cylinders and installed new piston rings. All valves have been re-ground, and the camshaft shows no signs of wear.
I don't quite understand why the engine control unit is injecting such a high fuel quantity at idle. I just checked data block 18 again, and there are no errors reported by the pump.
Translated on 22-07-2026, 11:56.
No new posts Document A3 8P1 Quattro up to week 34.04, fuel tank noises. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log MWB 003,011,072-077 Audi A6 3.0 TDI TT Quattro 165Kw Upload
No new posts Audi A6 4F 3.0 TDI Quattro - Steuerkette Diesel Engine Technology
No new posts Audi A4 B5 AFN Avant Quattro: standfest und alltagstauglich? Diesel Engine Technology
No new posts Audi A5 2015 3.0 TDI Quattro Steering Gear Replaced Transmission, Chassis, Body & Interior
