Resetting Serial Numbers in STG 03: How to Fix.
Dinli800
Post15-04-2023, 18:06    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
Hello everyone,
Today, I was planning to adjust the brake drying function on my 2020 Tiguan AD. Having done this on other cars in recent years, I knew exactly where to look.
However, there's nothing we can do to change that because, as you can see in the appendix, the operating number etc. has been reset to zero. (Or, as shown in the Screenshot, the VCDS suggestion of 12345 is already present.)
I've never seen anything like this before, and as you can see from the scan, other control units have data stored on them.
As I see it, neither the standard number 12345 nor any other number can be accepted, and the problem seems to be solely related to access permissions, as indicated by the error message that appears as a second notification.
The suggested price of 24990 is not an option.
Okay, here are my questions:
-Why is everything set to zero? Was something modified or tampered with (since it's a used purchase)?
-and of course, what login code do I need in this case to set the numbers and then be able to continue normally?
Daniel.
 File size:  19.03 KB
 Viewed:  715 times
 File size:  34.43 KB
 Viewed:  683 times
Log-WVGZZZ5NZLW349261-101702km.txt
 File name:  Log-WVGZZZ5NZLW349261-101702km.txt
 File size:  19.9 KB
 Downloaded:  600 times
Translated on 27-07-2026, 3:12.
Dinli800 likes this.
Post15-04-2023, 18:28    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
You can enter the numbers mentioned in the VCDS program settings.
The control units store the values of the last change, if available.
Car scans can serve as inspiration.
See also notes in:
https://shop.dieselschrauber.org/en/download/VCDS-Handbuch.pdf
Translated on 27-07-2026, 3:15.
Dinli800
Post15-04-2023, 20:59    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
I tried to illustrate the problem I'm facing in a short video.
I hope this works for you all.
Daniel.
Resetting Serial Numbers in STG 03: How to Fix. - VID-20230415-WA0000.mp4
 File size:  15.69 MB
 Viewed:  701 times
Post16-04-2023, 11:04    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
If you don't enter anything in the VCDS program settings, VCDS will attempt to use the values stored within the respective control unit.
If it shows "00000" or similar values, it won't work. Please enter valid values for WSC and other settings in the program configuration.
Where do you get the valid values from? Surely there are some included in every Autoscan. X
Translated on 27-07-2026, 3:16.
Dinli800
Post16-04-2023, 14:20    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
Hello Rainer,
I think I understand the part about valid values now.
I just did it with a completely fresh installation of VCDS: I entered the numbers first, then ran the connection test, saved the settings, and restarted.
Please see the video attachment for the rest of the information.
Resetting Serial Numbers in STG 03: How to Fix. - VID-20230416-WA0004.mp4
 File size:  16.03 MB
 Viewed:  328 times
Translated on 27-07-2026, 3:17.
Post16-04-2023, 14:31    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
OK... I will then check if I can find any information. I have already inquired with the manufacturer. icon_idea.gif
Translated on 27-07-2026, 3:18.
Ich_Can_nix
dieselschrauber and Dinli800 likes this.
Post16-04-2023, 20:43    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
Good evening.
As I understand it, you entered the login credentials for "General Customizations." However, the function you're looking for doesn't fall under that category.
According to my records, the login: 40304 is required for the brake disc drying process.
I would appreciate your feedback.
Michael.
Translated on 27-07-2026, 3:19.
Dinli800
dieselschrauber likes this.
Post17-04-2023, 17:32    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
Hello Michael.
I don't know where you got the 40403 from, but that number was actually at least a partial solution now. icon_smile_thumb_up.gif icon_smile_thumb_up.gif
Okay, so the brake drying process has now started, BUT I'm still getting errors related to those three numbers, as you can see in the video.
Resetting Serial Numbers in STG 03: How to Fix. - VID-20230417-WA0001.mp4
 File size:  16.94 MB
 Viewed:  295 times
Translated on 27-07-2026, 3:20.
Post19-04-2023, 19:17    Subject: Wiper Blades: Installation & Dry Wipe Guide Quote
Hello Rainer,
We don't have any personal experience with this modification on this particular car, but it would be worth considering.
Open the hood in case a diagnostic firewall prevents changes.
2) Use "44595" as the security access code according to this thread:
https://forums.ross-tech.com/index.php?threads/19270/
If this is still not accepted, the customer could try to save the existing value without making any changes. This could help determine whether the problem is due to a procedural issue or whether the module simply doesn't support that function.
Sincerely,
Andy
Translated on 27-07-2026, 3:21.
Dinli800
Post30-04-2023, 17:29    Subject: Brakes: Cleaning & Drying - How To Guide Quote
dieselschrauber wrote:
Hello Rainer,
If this is still not accepted, the customer could try to save the existing value without making any changes. This could help determine whether the problem is due to a procedural issue or whether the module simply does not support this function.
Andy
Sorry for the late reply, but I was only able to follow up on this today.
In short, the login code 44595 is not being accepted, regardless of whether the cover is open or closed.
And then, just for fun, using the login from above (40304), trying it again with an open hood doesn't achieve anything different.
Translated on 27-07-2026, 3:24.
Post30-04-2023, 17:45    Subject: Resetting Serial Numbers in STG 03: How to Fix. Quote
Sorry, thanks for the feedback! In that case, the ABS control unit simply won't support this setting.
Translated on 27-07-2026, 3:25.
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
No new posts Adjust idle speed On-Board Diagnostics (OBD)
No new posts Automatikschaltsoftware ändern?! Diesel Engine Technology
