ABS control unit new, and coding always resets to 00
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
hame22
Post06-05-2023, 19:24    Subject: ABS control unit new, and coding always resets to 00 Quote
Hello everyone,
Today, we have an ABS block included. Control unit.
exchanged. For a G6 TSI with 80 horsepower.
We entered the codes manually.
According to the report, it was also accepted.
If you turn off the ignition and then turn it back on...
If it goes into the braking electronics, everything resets to 0.
Tested with two different devices.
(Performed via Launch / VCDS).
Coding old control unit:
113B200D092200FD881204E4901F00403000
36 digits.
A different Golf 6 TSI with 122 horsepower has an ABS with...
38 positions.
Could this be tested?
143B400D092300FF281202E990200040310000
Can you simply add to the original encoding?
Please provide the text you would like me to translate from German to English. I will then provide the translation without any explanations.
Or does one need to perform the initial setup procedures beforehand?
process?
Post06-05-2023, 19:45    Subject: ABS control unit new, and coding always resets to 00 Quote
Autoscan.
hame22
Post10-05-2023, 23:53    Subject: ABS control unit new, and coding always resets to 00 Quote
Good evening.
It unfortunately took some time to receive the data.
Since I only use Launch X431, we need to organize something.
who has the VCDS.
He then created the LABAL files for us and provided them via USB.
Once with the old ABS module, and then with the second ABS module.
Best regards.
Log-ABS NEU-WVWZZZ1KZxxxxxxxx-94290km.txt
 File name:  Log-ABS NEU-WVWZZZ1KZxxxxxxxx-94290km.txt
 File size:  15.12 KB
 Downloaded:  531 times
Log-ABS ALT-WVWZZZ1KZxxxxxxxx-94290km.txt
 File name:  Log-ABS ALT-WVWZZZ1KZxxxxxxxx-94290km.txt
 File size:  11 KB
 Downloaded:  528 times
hame22
Post13-05-2023, 0:13    Subject: ABS control unit new, and coding always resets to 00 Quote
Evening everyone,
Today, I'm working on the launch again.
Everything's gone except for one mistake.
The encoding is now also saved.
He's still having trouble with the basic setup.
In the basic mode, 9 functions are displayed.
Do I have to go through all of them?
If so, is there a kind of guide on how to do that exactly?
Sure, please provide the text you would like me to translate from German to English. I will only provide the translation.
 File size:  2.44 MB
 Viewed:  388 times
hame22
dieselschrauber likes this.
Post13-05-2023, 7:49    Subject: ABS control unit new, and coding always resets to 00 Quote
Sure, here's the translation:
"Addendum:"
Error 01486 is gone.
Didn't explicitly mention it above.
There is only error 0003 remaining.
hame22
Post19-05-2023, 9:58    Subject: ABS control unit new, and coding always resets to 00 Quote
Morning,
Okay, all errors removed.
The basic setting for the intake valve is...
The shut-off valves were not fully closed.
Everything is connected. Everything is okay now.
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Transporter 7D, Bremsbelagverschleiß leuchtet immer Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD engine, 100,000 km, experiencing misfires and... Diesel Engine Technology
No new posts The cruise control is still not working! ? Diesel Engine Technology
No new posts 1Z Still Not Working: Troubleshooting Guide Diesel Engine Technology
No new posts Golf 3 TDI geht während der Fahrt immer aus On-Board Diagnostics (OBD)
