It also works without a fuel injector
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post24-06-2003, 12:17    Subject: It also works without a fuel injector Quote
I read a review today about the revised 2.5 V6 TDI engine.
This one already meets Euro IV standards.
The redesigned common rail injection pump now achieves over 2,000 bar.
To the best of my knowledge, this is a record for VP.
Cooled, digitally controlled exhaust gas recirculation and roller rocker arms are...
Only the most significant changes.
Not bad, I say[img][/img].
What do you think?
Or will it be surpassed by the new 2.5 R5 PD with VTG?http://home.t-online.de/home/bullitt667/smilies/data/uglyspitze.gif{MARKER}
Post24-06-2003, 12:48    Subject: It also works without a fuel injector Quote
Hi Tagessuppe,
We've already discussed this topic.
Tagessuppe
Post24-06-2003, 13:14    Subject: It also works without a fuel injector Quote
Okay, but my comment isn't just about the higher pressure.
but also to highlight the other innovations of the 2.5 V6 TDI engine.
But your contribution really contains everything important that needs to be said about the topic of VP.
Very informative.
Albrecht
Post24-06-2003, 13:54    Subject: It also works without a fuel injector Quote
I must also say that I was surprised when I read about the new 2.5 V6 engine with Euro 4 emissions standards.
This once again highlights the Volkswagen Group's leading expertise in diesel technology.
Regarding the R5 PD: it's probably less about which injection system is inherently better. This engine is narrower in width and also shorter in length due to the gear drive for the camshaft.
It's simply not easy to fit a V6 engine horizontally into a T5 bus or a Golf 5. The 6-cylinder gasoline engines are still VR engines (even though they no longer have that name), and therefore more compact than the V6 TDI.
I see the V6 engine more as a foundation for the larger and more powerful TDI engines, specifically the 3.0 V6, 3.3, and 4.0 V8 models.
Albrecht.
kenny
Post24-06-2003, 18:54    Subject: It also works without a fuel injector Quote
What exactly is 'digitally controlled AGR'? The EGR valve is already controlled by the engine control unit.
Or are the previous Bosch EDC analog computers icon_eek.gif?
Okay, here's the translation:
'But I have a question for the ESP and diesel tuning specialists: Could this potentially open the door to heavily modified 1.9 TDI engines with a new VP44 pump (if it's used in the V6) and 2000 bar injectors?'
Tagessuppe
Post25-06-2003, 7:56    Subject: It also works without a fuel injector Quote
kenny wrote:
What exactly is a "digitally controlled EGR" system? The EGR valve is already controlled by the engine control unit.
But a question for the ESP and diesel tuning specialists: Could this perhaps open the way for extremely modified 1.9 TDI engines with a new VP44 (if it's used in the V6) and 2000 bar injectors?
Regarding point 1: I believe we've already discussed this topic.
Regarding point 2: The 1.9 engine lacks 2 cylinders compared to the other option.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Does the engine control unit 028 906 021 AF have a WFS (W... On-Board Diagnostics (OBD)
No new posts Timing Belt Replacement: No Diagnostic Tool Needed? Diesel Engine Technology
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
