Polo 9N FSI engine control unit programming
juergenp.
Post16-08-2023, 20:38    Subject: Polo 9N FSI engine control unit programming Quote
Hello.
I have a Polo 9N FSI, manufactured in 2003, with engine code AXU.
"Because the vehicle is frequently driven short distances, I constantly receive the error code 17441 - NOx sensor (G295), P1033 - 35-00 - signal too low."
We have already replaced several NOx sensors in recent years.
I'm now having a problem where, when I install a new sensor (I still have 2 new ones), they simply don't respond at all. Read with VCDS.
All cables and connectors have been checked and tested.
A new flexible pipe has been installed in the exhaust system and checked for leaks.
NOx control unit replaced.
Since I still have another engine control unit (with the same OE number, AXU model, and software version), I wanted to test it to see if that might be the problem.
My question is how to do this using VCDS. Login codes for the speedometer and engine control unit are available.
Sure, here's the translation:
"LG" translates to "Best regards" or "Sincerely" in English.
Post16-08-2023, 20:44    Subject: Polo 9N FSI engine control unit programming Quote
Unfortunately, at the moment, only older engine control units can be linked to the immobilizer using VCDS. This depends on the generation of the immobilizer.
I would suggest searching online for the VAG part number of your engine control unit to see if there is a newer software version available.
http://wiki.ross-tech.com/wiki/index.php/ImmobilizerSoftware version of the ECUhttps://wiki-ross--tech-com.translate.goog/wiki/index.php/Immobilizer?_x_tr_sch=http&_x_tr_sl=en&_x_tr_tl=de&_x_tr_hl=de&_x_tr_pto=wapp
juergenp.
dieselschrauber likes this.
Post17-08-2023, 9:29    Subject: Polo 9N FSI engine control unit programming Quote
Hello.
Okay, hier ist die Übersetzung:
"This is about the immobilizer, Generation 3." Regarding the software version, there are no updates available beyond version 4884.
Jürgen
Post17-08-2023, 9:59    Subject: Polo 9N FSI engine control unit programming Quote
Fixed the second link above. Regarding the NOx error with a low signal: Is there a measured value within the engine control unit (ECU) where this can be checked?
This would greatly simplify the inspection of the wiring or the entire system. icon_idea.gif
juergenp.
Post22-08-2023, 8:14    Subject: Polo 9N FSI engine control unit programming Quote
Hello.
I checked the cables for continuity, but I'm not yet sure exactly which readings I should be looking for.
Post22-08-2023, 17:34    Subject: Subject: Re: Pairing/Programming ECU for Polo 9N FSI engine Quote
juergenp. wrote:
Hello.
I have checked the cables for continuity.
However, I haven't yet figured out exactly which measurement values I should be paying attention to.
Whether the sensor is receiving its supply voltage, whether the output signal from the sensor is within the expected range, and whether it also arrives at the connector of the control unit in that manner. icon_idea.gif
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit (ECU) Calibration for WFS On-Board Diagnostics (OBD)
No new posts Golf 4 engine control unit programming On-Board Diagnostics (OBD)
No new posts Immobilizer: Engine Control Unit (ECU) Not Learning On-Board Diagnostics (OBD)
No new posts VW Polo 6N: Key Programming Guide On-Board Diagnostics (OBD)
