Exhaust Gas Recirculation Sensor Error T6 15560
dieselschrauber and Herbert likes this.
Post19-07-2023, 14:07    Subject: Exhaust Gas Recirculation Sensor Error T6 15560 Quote
Hello everyone, after a long time, I'm reporting again icon_biggrin.gif.
I have a T6 with a CXFA engine and 81,000 km on it that has the following issue. This problem only occurs when driving longer distances, starting from around 260 km or more continuously; it doesn't happen for shorter trips. It's very strange. Is anyone familiar with this type of error?
Monday, July 17, 2023, 5:00:26 PM: 22077
VCDS - A Windows-based VAG/VAS emulator that runs on Windows 10 x64.
VCDS version: RKS 21.3.0.0
Data as of: 20210308 DS325.0
http://shop.dieselschrauber.org/en
Dealer/Workshop name: VW
Company number: 010 00032 000010
Vehicle Identification Number (VIN): WV2ZZZ7HZGH138028 License plate:
Mileage: 80350 Repair order: geibel
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Address 01: Engine Control Module
Label file: DRV\04L-907-309-V2.clb
Control unit part number: 04L 906 056 KH. Hardware version: 04L 907 445.
Component and/or version: R4 2.0L TDI H02 6184.
Encoding: 0025401C437401080000
Operating number: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KH 004013 (VN75)
ROD: EV_ECM20TDI03004L906056KF.rod
text
VCID: 7DF5AEE6ECA75363A8-8028
Two error codes found:
15560 - Exhaust gas recirculation (EGR) valve, donor part.
P046C 00 [047] - Implausible signal.
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 2.
Mileage: 78897 km
Date: 2079.01.21
Time: 13:55:40
Motor speed: 0.00 rpm.
Normalized load value: 0.0%
Vehicle speed: 0 km/h
Coolant temperature: 89 °C.
Intake air temperature: 19 °C
Atmospheric pressure: 930 millibars.
Voltage at terminal 30: 12.265 V.
Lost learning counter via OBD: 40.
Air mass sensor 1 bank 1 air mass: Raw value: 0.0 mg/stroke.
Exhaust Gas Recirculation (EGR) Valve, Bank 1: Stored Fault Code - Target Value: -4.62 %.
Exhaust Gas Recirculation (EGR) Valve, Bank 1: Stored Fault Code - Live Value: 17.41%
Exhaust Gas Recirculation (EGR) Valve, Bank 1: Stored fault code - Offset closed: 0.00 %.
Exhaust Gas Recirculation (EGR) Valve, Bank 1: Stock Availability - Raw Value: 2.809 V
Exhaust gas recirculation valve, bank 1: fault detected. Cooling operation: 2.368 V.
Exhaust gas recirculation valve, bank 1: fault detected. Bypass operation: 2.790 V.
32807 - Exhaust gas recirculation (EGR).
P2457 00 [236] - Insufficient cooling performance.
Warning light ON - Intermittent - Confirmed - Checked since last reset.
Error priority: 2
Error frequency: 11
Mileage: 79,008 km
Date: 2081.01.21
Time: 21:18:03
Motor speed: 1709.50 rpm.
Normalized load value: 80.8%
Vehicle speed: 94 km/h
Coolant temperature: 78 °C
Intake air temperature: 29 °C
Ambient air pressure: 1000 millibars.
Voltage at terminal 30: 14.304 V.
Air mass at air mass flow sensor 1: 90.0 kg/h.
Normalized airflow ratio: 1.638 counts.
Exhaust Gas Recirculation (EGR) Valve, Bank 1: Stored fault code - Actual value: -40.25 %.
Throttle valve control (bank 1): In stock - Actual value: 51.11 %.
Boost pressure: Target value: 1.481 bar.
Absolute intake pressure: 150 kPa absolute.
Medium injection volume: 20 mg/stroke.
Index of the current operating mode for the motor: 0.
Index of the next requested operating mode: Motor: 0.
Index of target operating mode (motor): 0.
Readiness: Not Available
Translated on 28-07-2026, 6:31.
Herbert and E30_V8 likes this.
Post19-07-2023, 19:57    Subject: Exhaust Gas Recirculation Sensor Error T6 15560 Quote
Hi Kai,
I can't think of any errors off the top of my head.
32807 - Exhaust gas recirculation.
P2457 00 [236] - Insufficient cooling performance:
Could it be that the EGR cooler control is not working correctly, and that the resulting errors are secondary problems caused by the excessively high temperature of the recirculated exhaust gases?
I would start by using the VCDS control module test to see if the EGR cooler can be switched on and off. I haven't found anything specific for the T6, but it seems there isn't a vacuum-operated actuator with a stepper motor, possibly indicating an electric system.
There is also a temperature sensor located at the back of the EGR valve, near the EGR cooler, which I would also check.
Edit: I recommend SSP 564 - The 2.0-liter TDI engine in the T6.
Exhaust gas aftertreatment, page 27 and following.
SSP 564 wrote:
Exhaust gas recirculation cooler bypass valve.
N345
and
Pump for the exhaust gas recirculation cooler, V400.
Translated on 28-07-2026, 6:42.
dieselschrauber likes this.
Post20-07-2023, 8:43    Subject: Exhaust Gas Recirculation Sensor Error T6 15560 Quote
Hi there,
Does the error occur in connection with DPF regenerations? The distances of 260 km or more might correspond to the regeneration intervals.
Translated on 28-07-2026, 6:45.
Post20-07-2023, 11:23    Subject: Exhaust Gas Recirculation Sensor Error T6 15560 Quote
Thanks for the tip, I'll go ahead and replace the temperature sensor after the EGR cooler.
You can tell if the EGR valve is working by removing the plastic cover from the mechanism.
Let's see if it stays away after a long drive of over 260 kilometers.
It's strange that it only happens on long drives; when I take it for a test drive, it doesn't occur.
Herbert: I'm afraid I don't know if that has anything to do with regeneration, Grübbel.
Translated on 28-07-2026, 6:46.
No new posts P0487 - Exhaust Gas Recirculation (EGR) Throttle Control ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust gas recirculation: function and problem areas Technical Articles
No new posts P0400 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EGR Valve Error 4891 - Seat CFH (N18) Diesel Engine Technology
No new posts VW T4 2.5 TDI ACV Error: Throttle Position Sensor Diesel Engine Technology
No new posts Oil level/temperature sensor On-Board Diagnostics (OBD)
No new posts Error 18047 - Accelerator Pedal Sensor Diesel Engine Technology
