abicim
Joined: 11/26/2020 Posts: 23 Karma: +7 / -0 Location: Furtwangen
14-11-2022, 19:12 Subject: BKD engine running rough |
Hello everyone,
My Golf 5 2.0 TDI with a BKD engine is unfortunately running unevenly, both when stationary and sometimes while driving.
I once used VCDS to check the fuel quantity deviations, but I can't tell if the values are within acceptable limits or not. I want to narrow down the problem to see if it's the injectors or the fuel pump module. What do you think about that?
Mileage: 176,000 km
E30_V8 Profi-Schrauber
Joined: 06/15/2022 Posts: 94 Karma: +111 / -0 Location: ...aus dem Herzen der Natur! 2005 Skoda Fabia  Premium Support
dieselschrauber likes this. |
14-11-2022, 23:00 Subject: BKD engine running rough |
Unfortunately, the video and the photo are not loading for me.
Quote: | | My Golf 5 2.0 TDI with a BKD engine unfortunately runs unevenly, both when stationary and to some extent while driving. |
Most often, you'll hear signs of a failing dual-mass flywheel before you actually feel them!
Quote: | | I once looked at the quantity deviations using VCDS, but I can't tell whether the values are okay or not. |
Are there any outliers, either above or below, in one or more cylinders with respect to the amount of material?
Best regards, Richard.
Polo V 1,6 Tdi (CAY)
Profile PM Garage |
abicim
15-11-2022, 18:34 Subject: BKD engine running rough |
Occasionally, I hear a clicking sound, but I can't currently determine whether it's caused by the dual-mass flywheel (DMF) or by the uneven running of the engine.
Here are the values I have:
At coolant temperature: 12.6°C.
Cylinder 1 = -1.04 mg/H.
Cylinder 2 = 0.47 mg/H
Cylinder 3 = 0.19 mg/H
Cylinder 4 = 0.35 mg/H
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
15-11-2022, 21:27 Subject: BKD engine running rough |
abicim wrote: | From time to time, a clicking sound can be heard, but I am currently unable to determine whether this is due to the dual-mass flywheel (ZMS) or the uneven running of the engine.
Cylinder 4 = 0.35 mg/H |
Okay.
Profile PM WWW Garage |
abicim
dieselschrauber and E30_V8 likes this. |
20-01-2023, 1:46 Subject: Problem solved |
Just wanted to give a quick update: I've completely replaced the ZMS (presumably referring to a clutch master cylinder), and the clicking noise and uneven running have been fixed.
You're welcome.
Best regards, Orhan.
20-01-2023, 11:03 Subject: BKD engine running rough |
Thank you for the feedback  .
Profile PM Garage |
abicim
02-12-2023, 22:45 Subject: Still experiencing some lag |
Here's a short update: I've noticed that the slight jerking is still present, even though the clutch master cylinder (ZMS) was replaced months ago. I feel this jerking mostly when the car is stationary. I'm also occasionally experiencing a problem where the clutch pedal gets stuck down and doesn't return to its normal position, which I then have to manually lift with my foot. I suspect the issue might be related to the bleed valve or the slave cylinder. Can this cause also be responsible for the stuttering?
04-12-2023, 19:05 Subject: Subject: Re: Unfortunately, the stuttering is still present |
abicim wrote: | | Short feedback: I've noticed for months that a slight jerking is still present, even though the clutch master cylinder (ZMS) has been replaced. I feel this jerking when the car is stationary. I occasionally have the problem that the clutch pedal stays down and doesn't return, which I then have to lift with my foot. I suspect it's related to the bleed valve or the slave cylinder. Can this cause also be the reason for the stuttering? |
"Ruckeln" is a broad term. Please define more precisely how it manifests itself. The idle speed readings are within the normal range, and there's no reason for any jerking or hesitation.
The problem with the clutch operation usually has nothing to do with the jerking.
If the clutch pedal stays down, does the clutch disengage at all?
