Horstel
17-10-2005, 19:03 Subject: Encode the second control unit to wfs |
Unfortunately, I still haven't found an answer to my question, even after searching the forum.
I want to code a second control unit with a tuning chip for my 1Z engine.
Does the original control unit remain suitable for reinstallation after the new control unit has been programmed, or does it also need to be reprogrammed?
More precisely, can I theoretically use both of them?
Thank you for any potential response.
Horstel.
17-10-2005, 19:08 Subject: Encode the second control unit to wfs |
The WFS (Warm-Function Specification) is adapted to match the specific engine control unit (ECU).
This process must be repeated every time an engine control unit (ECU) is replaced.
Profile PM WWW Garage |
donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
19-10-2005, 20:45 Subject: Encode the second control unit to wfs |
... unless the data states in both MSGs have the same identifier  .
Touran 1.9 TDI, EZ 09/2004
19-10-2005, 21:43 Subject: Encode the second control unit to wfs |
Correct
Horstel
20-10-2005, 7:29 Subject: Encode the second control unit to wfs |
Regarding MSGs, they have the same identifier.
Can this be read out from an MSG using VAG-COM, and can the value be changed accordingly?
Or is that hardware?
Horstel.
Rudi Guest
20-10-2005, 8:11 Subject: Encode the second control unit to wfs |
Identifier and identifier...
It's not just about the part number.
To truly make the STGs interchangeable, one needs to do something.
to tinker with it and reprogram it (which has nothing to do with chip tuning).
VAG-COM doesn't provide any helpful information.
Rudi
22-11-2023, 21:27 Subject: Encode the second control unit to wfs |
huebi wrote: | Hi everyone.
The data is stored in the flash memory, and that's also where the tuning adjustments are made.
Then there's the EEPROM, which stores the coding, adaptation values, mileage, and data for the immobilizer. In the case of the EDC15 and EDC16 systems, the EEPROM can also be read out and written to the second control unit via the OBDII interface. Then, the simple device replacement, as it worked for me, should function well.
huebi |
 Thank you!
