NOX Bank1 P2200 - Electrical Fault
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post25-11-2024, 21:34    Subject: NOX Bank1 P2200 - Electrical Fault Quote
Hello everyone,
I replaced the DPF (Diesel Particulate Filter) on my T6 CXHA engine at 314,000 kilometers.
After driving 140km, the MKL light illuminates. A fault code P2200, indicating an electrical issue with the NOX sensor bank 1, was found using VCDS 32137.
Is this the sensor located after the DPF, requiring a 22mm wrench?
How can I check the oxygen sensors using VCDS? Thank you for your help. Best regards, Wolfgang.
Back to top Profile PM Email
Post25-11-2024, 22:35    Subject: NOX Bank1 P2200 - Electrical Fault Quote
I don't quite understand the problem.
Check the wiring harness/connector. If nothing is visible, clear the error codes, start the engine, and then gently wiggle or move each cable individually.
Then you can check the error memory to see if the problem is with the cable or the sensor itself.
Schmierpfote
Post25-11-2024, 22:47    Subject: NOX Bank1 P2200 - Electrical Fault Quote
Hello Rainer,
Schmierpfote
dieselschrauber and Herbert likes this.
Post26-11-2024, 13:49    Subject: NOX Bank1 P2200 - Electrical Fault Quote
Hello everyone in the forum,
NOX sensor installed by Metzger.
T6 is running again.
Post26-11-2024, 21:39    Subject: NOX Bank1 P2200 - Electrical Fault Quote
Schmierpfote wrote:
Hello to the forum,
Greetings Wolfgang
Thank you for your feedback!
Was was the outage foreshadowed? And is the NOx reduction now working at an adequate rate?
Schmierpfote
dieselschrauber and Turbinchen likes this.
Post26-11-2024, 21:51    Subject: NOX Bank1 P2200 - Electrical Fault Quote
Hello Rainer,
The DPF contained 128.8 grams of oil ash. The maximum load according to VCDS is 110 grams. No error messages were received.
Therefore, the DPF was replaced and the old sensors were reinstalled.
See my question in the forum on November 25, 2024, at 20:34.
No new posts Electric auxiliary heater, smell of burning, Audi A4 A5 Q5 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spark Plug Problem: Electrical Fault Diagnosis On-Board Diagnostics (OBD)
No new posts RNS E: 16352 - Steuergerät - Electrical Fault 014 - Defect On-Board Diagnostics (OBD)
No new posts VW T4 2.5 TDI ACV Error: Throttle Position Sensor Diesel Engine Technology
No new posts Oil level/temperature sensor On-Board Diagnostics (OBD)
