Calibrating the intake manifold pressure sensor on a 1.4 TSI engine
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
harzer1
Post30-01-2024, 16:55    Subject: Calibrating the intake manifold pressure sensor on a 1.4 TSI engine Quote
Hello, I replaced the potentiometer for the intake manifold flaps on my Golf 5, 1.4 TSI, BLG engine.
Erwin (siehe Fehlerdatenbank) VW states that after the replacement, the learned values should be erased and the engine control unit should be reprogrammed.
Is this path available in VCDS as well?
Karma: +782 / -0   Thank you, like it!
Post30-01-2024, 18:05    Subject: Calibrating the intake manifold pressure sensor on a 1.4 TSI engine Quote
Autoscan is missing... I would say, based on my gut feeling, that the adaptation channels from the engine control unit should be checked.
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wie Lenkwinkelsensor neu anlernen? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 Schlüssel beim A8 anlernen?geht das? On-Board Diagnostics (OBD)
No new posts Neue Schlüssel anlernen beim Audi A8 4E On-Board Diagnostics (OBD)
No new posts ESP vergleich > Poti- u. HDK Geber Diesel Engine Technology
No new posts Fehlerspeicher MKB 1Z: Poti für Schieberweg - G99 Diesel Engine Technology
