Audi A5 throttle body
chli1976
Post03-02-2024, 20:04    Subject: Audi A5 throttle body Quote
I replaced the throttle body on an A5 V6; the plastic teeth on the old one were worn out.
"It was originally a VDO part, but I installed a Pierburg one, and it also works with the actuator diagnostics."
Error rate is 0.00 / minute.
I tested the cables under load (H4 lamp) and they are in good condition.
What bothers me are the values for "Throttle Offset Closed" and "Throttle Offset Open," as they also fluctuate while the system is running (as seen in the log file).
There are no built-in options for adaptation in the default settings.
The new DK might have a bug.
DK.xlsx
 File name:  DK.xlsx
 File size:  17.61 KB
 Downloaded:  206 times
Log-WAUZZZ8T68A043356.txt
 File name:  Log-WAUZZZ8T68A043356.txt
 File size:  3.28 KB
 Downloaded:  674 times
VCDS
Translated on 09-07-2026, 9:36.
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 Throttle Body, cannot set default settings Gasoline Engine Technology
No new posts Throttle valve - error Diesel Engine Technology
No new posts Adapt throttle valve Lupo 16V Gasoline Engine Technology
This topic is locked, you cannot edit or reply. Throttle Body Cleaning: T3 WBX (Solved) Gasoline Engine Technology
