Audi A8: Start-stop system doesn't always work
matthias.stender
Karma: +9 / -0   Thank you, like it!
Post18-03-2024, 22:54    Subject: Audi A8: Start-stop system doesn't always work Quote
Hello Diesel Forum,
For the past few weeks, the start-stop system in my A8 has been working very rarely. Sometimes, after long downhill drives, it works again for 2-3 times, but then it stops working again. I once monitored the parameters for start-stop in the diagnostics of the transmission and engine, and everything was "ready," but when I query the vehicle's system, the engine reports an error related to the transmission temperature.
How can I pinpoint the exact parameter that is repeatedly preventing the start-stop function from working? I have attached the VCDS log, but there are no errors visible in it.
Is there a guided troubleshooting process available?
Best regards, Matthias.
Saturday, February 3, 2024, 09:47:29:06315
VCDS - A Windows-based VAG/VAS emulator that runs on Windows 10 x64.
VCDS version: RKS 23.3.1.0, HEX-V2 CB: 0.4631.4
Data as of: 20231010 DS346.2
http://shop.dieselschrauber.org/en
Dealer/Workshop name: datac
Company number: 758 02325 000200.
Vehicle Identification Number (VIN): WAUZZZ4H2DN026221
License plate: A-MS 537
Mileage: 257812 km. Repair order: Redjag reset.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Vehicle type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 28 34 36 3B 3C 42
46 47 52 53 55 56 _ 62 69 6C 6D 6F 72 81 85 88 89 8B 8E 8F
90
Vehicle Identification Number (VIN): WAUZZZ4H2DN026221. Mileage: 257,812 km.
01-Motor electronics -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
Front passenger seat adjustment - Status: OK.
08-Climate control/heating unit - Status: OK.
09-Central Electrical System -- Status: OK.
Parking Assist System 2 -- Status: OK 0000
13-point distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
28-Heating/Climate system - Current status: OK.
34-Level regulation -- Status: OK.
36-seat adjustable passenger seat -- Status: OK 0000.
3B Sensor Electronics -- Status: OK 0000
3C Lane Change -- Status: OK 0000
42-door electric driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Beam adjustment. -- Status: OK 0000.
56-Radio -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000.
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
6C Rear View Camera -- Status: OK 0000
Rear hatch (6D) - Status: OK 0000.
6F Comfort System II -- Status: OK 0000.
72- Door, electric, high, right side -- Status: OK 0000
81-Selector lever -- Status: OK 0000
85-Camera Controller -- Status: OK 0000
88-Multi-contour driver's seat -- Status: OK 0000
Front passenger seat with multi-contour function -- Status: OK.
8B Distance Rule 2 -- Status: OK 0000
8E Image Processing -- Status: OK 0000
Left side seatbelt pretensioner -- Status: OK.
Right side seat belt pretensioner -- Status: OK.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Feld und lässt das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine Control Module (J623-CDTA)
Label file: None.
Part number SW: 4H0 997 401, HW: 4G0 907 401.
Component: 3.0 TDI EDC17 H40 0004.
Revision: 53H40--- CVN: E5284ADE
Encoding: 0A2A401A056601020000
Operating number: WSC 42182 003 1048576
ASAM Dataset: EV_ECM30TDI0114H0997401 001004
ROD: EV_ECM30TDI0114H0997401.rod
VCID: 6A8C3F329CFE63EAB1F-803E
VINID: 9D196AAAA118094780086082045BE1AB05
No error codes found.
Readiness: 0 0 0 0 0
Address 02: Transmission (J217) Label file: | DRV\0BK-927-156.clb
Part number SW: 4H1 927 158 BG, HW: 0BK 927 156 AG.
Component: 0BK 30 TDIRdW H16 1011
Revision: --H16--- CVN: 1957008C
Encoding: 000001
Operating number: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX51011 002018
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 76B41B42D846B70A257-8022
Address 03: Brake Electronics (J104)
Label file: 4H0-907-379.clb
Part number SW: 4H0 907 379 E, Part number HW: 4H0 907 379 E.
Component: ESP PREMIUM H10 0352
Revision: -------- Serial Number: --------------
Encoding: 60E5A30006A7C500E300
Operating number: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3430E14A8EBAE51ADB3-8060
Address 05: Access/Startup Authorization (J393)
Label file: .DRV\8K0-907-064-05.clb
Part number SW: 4H0 907 064 CB. Part number HW: 4H0 907 064 CB.
Component: BCM2 2.0 H33 0433
Revision: 00002001
Encoding: 05A72F46000000000000
Operating number: WSC 02313 785 00200
VCID: 6B823A3693847AE2CA9-803E
Address 06: Front Seat Adjustment (J521)
Label file: None
Part number SW: 4H0 959 760 D, Part number HW: 4H0 959 760 D.
Component: MEM-BFS H08 0153
Revision: AA000000 Serial Number: 00000051858949
Encoding: 0018320000047201000001010101112131313333283333
VCID: 3430E14A8E3AE51ADB3-8060
Address 08: Climate Control/Heating Unit (J255)
Label file: | DRV\4H0-820-043.clb
Part number SW: 4H0 820 043 K, Part number HW: 4H0 820 043 K.
Component: Climate control system, 4 zones, H20 0130.
Encoding: 361101B83C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 2808053A427291FA67B-807C
Address 09: Central Electronics (J519)
Label file: .DRV\4H0-907-063-V1.clb
Part number SW: 4H0 907 063 CD, HW: 4H0 907 063 D.
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial Number: 00000001510337
Encoding: 26002010C034AFE38B810007A0001D0C009CC30806010101800008406001
Operating number: WSC 21411 004 1048576
VCID: 6C80392A968A7DDAC33-8038
Subsystem 1 - Part number SW: 4H1 955 119 C, HW: 4H1 955 119 A, Label file: DRV\1KX-955-119.CLB.
Component: WWS641 121121 H35 0080
Serial number: 130205200703
Encoding: 0045F7
Subsystem 2 - Part number SW: 8K0 955 559 C, HW: 8K0 955 559 C, Label file: DRV\8K0-955-559.CLB.
Component: RLS H04 0003.
Serial number: 10312393
Encoding: 025523
Subsystem 3 - Part number SW: 4H0 941 531, HW: 4H0 941 531.
Component: E1 - LDS H07 0044.
Serial number: 13 02 2013 00000193
Subsystem 4 - Part number SW: 4H0 907 705 K, HW: 4H0 907 705 C.
Component: EVLS-SG H08 0300
Serial number: WA104612000002734529.
Encoding: 020300
Subsystem 5 - Part number SW: 4H0 907 658, HW: 4H0 907 658.
Component: AQ_Hum_Sensor H03 0003.
Serial number: EE48C496000000000001.
Address 10: Parking Assist 2 (J446) Label file: | DRV\4H0-919-475-7X2.clb
Part number SW: 4H0 919 475 AA, Part number HW: 4H0 919 475 AG.
Component: PARK ASSIST SYSTEM H01 0083
Revision: 11001001 Serial Number: 61061305300203
Encoding: A80B02
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BE285EB1289032F05-8024
Address 13: Distance Control (J428)
Label file: | DRV\4H0-907-561.clb
Part number SW: 4H0 907 561 B, Part number HW: 4H0 907 561 B.
Component: ACC3 H19 0410
Serial number: 00000000000000 Data version number: 4H0909863D 0029
Encoding: 7F04010201
Operating number: WSC 23332 004 104857
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A0CFF325C7EA3EA71F-807E
Address 15: Airbag (J234) Label file: | DRV\4H0-959-655.clb
Part number SW: 4H0 959 655 C, Part number HW: 4H0 959 655 C.
Component: Airbag
Part Number: 10.43 H43 0040
Revision: -------- Serial Number: 003JG00BXTUC Data Status Number: 4H0909602F 0006
Encoding: 30314246323430303033554A304C34483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3634DB4298C6F70AE57-8062
Crash sensor for driver-side side airbag:
Serial number: 3575HRB400E50CQ0FHFB.
Crash sensor for side airbag, passenger side.
Serial number: 3585HRB400K50CQ0A8UJ
Rear side airbag crash sensor (driver's side).
Serial number: 3515JRB400250DEKJ0U6
Rear side airbag crash sensor, passenger side.
Serial number: 3525JRB400450DEKM8VL
Front airbag crash sensor (driver side):
Serial number: 3554VRB401I50D5SBI8P
Crash sensor for front airbag, passenger side.
Serial number: 3564VRB401I50D5SFHBW.
Address 16: Steering wheel electronics (J527)
Label file: .DRV\4H0-953-568.clb
Part number SW: 4H0 953 568 G. Part number HW: 4H0 953 568 G.
Component: Steering module H03 0005.
Revision: -------- Serial Number: 90815MBF0002N
Encoding: 00003C
VCID: 372AD6469F4C0E02FE1-8062
Subsystem 1 - Part number SW: 4H0 951 528 A, HW: 4H0 951 528 A.
Component: E221 - MFL H08 0010
Serial number: 24 11 2012 A0129992
Address 17: Control panel module (J285)
Label file: | DRV\4H0-920-xxx-17.clb-SRI1
Part number SW: 4H0 920 930 M, Part number HW: 4H0 920 930 M.
Component: TDieRDWACC--- H50 0515
Revision: 34081076 Serial Number: 658180213592036
Encoding: 138608001F440008000000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 3038ED5A7AA2D93ABFB-8064
Analog clock:
Subsystem 1 - Part number SW: 4H0 919 204 H, HW: 4H0 919 204 H.
Component: Analog clock D4 H05 0225.
Serial number: 2130206001597
Address 18: Auxiliary heater (J364) Label file: .DRV\8R0-265-105.clb
Part number SW: 4H0 265 105 E, Part number HW: 4H0 265 105 E.
Component: Auxiliary heater H24 0260.
Revision: 66006006 Serial Number: 20130131222726
Encoding: 5D1F01
VCID: 2410110A3EDA759A4B3-8070
Address 19: Diagnostic Interface (J533)
Label file: | DRV\4H0-907-468.clb
Part number SW: 4H0 907 468 AC, Part number HW: 4H0 907 468 AC.
Component: J533 -- Gateway H12 0037
Revision: -------- Serial Number: 00000000830005 Data Status Number: 4H0909515F 0070
Encoding: 00CD077D00
GVL: FFAFF84CFEE7E0CCC000
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72BC2752B42EAB2A09F-8026
Battery monitoring control unit:
Subsystem 1 - Part number SW: 4H0 915 181 F, HW: 4H0 915 181 F.
Component: J367-BDM H08 0181
Serial number: 00000000001911022285
Voltage stabilizer:
Subsystem 2 - Part number SW: 8K0 959 663 C, HW: 8K0 959 663 C.
Component: J532_DCDCStab H05 0006
Serial number: 13044001407021200410
Address 28: Heating/Climate control (E265) Label file: | 4H0-919-158.clb
Part number SW: 4H0 919 158 K, Part number HW: 4H0 919 158 K.
Component: Climate control vent H16 0121
Encoding: 2100000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirConditioningRear_AU64.rod
VCID: 3828D57A92D2017AF7B-806C
Address 34: Level Control (J197)
Label file: .DRV\4G0-907-553.clb
Part number SW: 4H0 907 553 E, Part number HW: 4H0 907 553.
Component: AIR DAMPER H17 0099
Data status number: 4H0909553G 0036.
Encoding: 008003
ASAM Dataset: EV_AirSuspe 003024
FILE: EV_AirSuspe_VW51.rod
VCID: 2E04F3226096CFCAAD7-807A
Address 36: Seat adjustment for driver (J136)
Label file: None
Component: MEM-FS H08 0153
Revision: AA000000 Serial Number: 00000051858819
Encoding: 00183B0000057201000001010101112131313333203333
Address 3B: Sensor electronics (J849)
Label file: 4G0-907-637.clb
Part number SW: 4H0 907 637 K, Part number HW: 4H0 907 637 F.
Component: SARA 6D H02 0056
Revision: -------- Serial Number: EJ1BPA7700KNGO
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372AD6469FCC0E02FE1-8062
Address 3C: Lane Change
Label file: DRV\4G0-907-566-V1.clb
Part number SW: 4H0 907 566 A, Part number HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial Number: 6PZ 010 287-07
Encoding: 0000101
VCID: 2E04F3226C16CFCAAD7-807A
Subsystem 1 - Part number: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27.
Subsystem 3 - Serial Number: 5F14.02.1300H02000AMS14909
Subsystem 4 - Serial number: S14909.
Address 42: Door electrical driver (J386) Label file: .4H0-959-793.clb
Part number SW: 4H0 959 793 R, HW: 4H0 959 793 G.
Component: TSG FA H06 0273
Revision: -------- Serial Number: 0000052468981
Encoding: 011F12005E00628202083013
Operating number: WSC 02312 785 00200
VCID: 48C8A5BAE2B271FA87B-801C
Address 46: Comfort System (J393) Label file: .DRV\4H0-907-064-46.clb
Revision: 00002001 Serial number: 0300722069
Encoding: 011A0E2000B93485B320C7C40E03010F0000000000000000000000000000
Operating number: WSC 02311 785 00200
Subsystem 1 - Part number: 4H0 951 177.
Component: DWA sensor H01 0010.
Subsystem 2 - Part number: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501.
Subsystem 3 - Part number SW: 4H0 959 591, HW: 4H0 959 591.
Component: J245 PS50.030 H07 0006.
Serial number: WOO2016086 /
Coding: 901F00
Subsystem 4 - Part number SW: 4H0 947 135 G, HW: 4H0 947 135 G.
Component: Roof electronics H13 0080.
Serial number: A2013000000000679540.
Encoding: 010000
Subsystem 5 - Part number SW: 4H0 959 591 A, HW: 4H0 959 591 A.
Part number: V252 PS010 H05 0005.
Serial number: WOO1000W46H
Subsystem 6 - Part number SW: 3AA 962 243, HW: 3AA 962 243.
Component: GEB.F.Heckoef H12 0719
Serial number: 84346539
Address 47: Soundsystem (J525) Label file: DRV\4G0-035-223.clb
Part number SW: 4G0 035 223 C, HW: 4G0 035 223 A.
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial Number: 00000000033470
Encoding: 030000
VCID: 1D6624EE1DB0445204D-8048
Address 52: Power door lock, front passenger side (J387) Label file: .4H0-959-792.clb
Part number SW: 4H0 959 792 H HW: 4H0 959 792 H
Component: TSG BF H06 0273
Revision: -------- Serial Number: 0000049219155
Encoding: 011F12005E00628202083002
Operating number: WSC 30483 001 1048576
VCID: 3D26C46EBD70245224D-8068
Address 53: Parking brake (----)
Label file: DRV\4H0-907-801.clb
Part number SW: 4H0 907 801 F, HW: 4H0 907 801 A.
Component: EPB-4 H03 0013
Revision: -------- Serial Number: 00000000601746 Data Version Number: 4H0909522C 0011
ASAM Dataset: EV_ParkBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B02FA365384BAE28A9-807E
Address 55: Headlight range adjustment (J431) Label file: | DRV\8X0-907-357.clb
Part number SW: 4H0 907 357 B. Part number HW: 4H0 907 357 B.
Bauteil: ....LWR12.... H02 0010
Serial number: 130221-0002-008.
Encoding: 11116F101002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2D06F42E6D90B4D294D-8078
Address 56: Radio (R) Label file: .DRV\4F0-035-0xx-56.clb
Part number SW: 4H0 035 061 N, Part number HW: 4H0 035 061.
Component: Radio with DAB functionality. Part number: H60 0139.
Revision: AB001007 Serial Number: 440B$0D7519676
Encoding: 010103010000000001
VCID: 290E003E59F8A8F2785-807C
Address 5F: Information selection. I (J794) Label file: .DRV\4E0-035-6xx-5F.clb
Part number SW: 4H0 035 670 P, HW: 4H0 035 670 N.
Component: H-BNT-EU H45 0798
Revision: -------- Serial Number: 179B%0D7508266
Encoding: 020100000001FBEF75B08B1E00000003080001000000000000
VCID: 313EE85E7128D032B05-8064
Subsystem 1 - Part number: 8R0 060 884 JN
Component: EUR 2022 3401
Subsystem 2 - Part number SW: 4H0 919 604 G, HW: 4H0 919 604 G.
Component: DU8 D4 SV NB H48 0021
Serial number: AUZ8ZDCC9004W9.
Subsystem 3 - Part number SW: 4H1 919 600 H, HW: 4H1 919 600.
Component: E380 BDT D4 H09 0065.
Serial number: 00000000105404
Subsystem 4 - Part number: 8R0 060 961 E.
Component: CD Database 4949.
Address 62: Door electric, left/right (J388) Label file: .4H0-959-795.clb
Part number SW: 4H0 959 795 E. Part number HW: 4H0 959 795 E.
Component: TSG HL H06 0273
Revision: -------- Serial Number: 0000052263623
Encoding: 010F12004000628202083003
Address 69: Trailer (J345) Label file: .DRV\4H0-907-383-V1.clb
Part number SW: 4H0 907 383 C. Part number HW: 4H0 907 383 C.
Part: Trailer H12 0100
Revision: 5H001001 Serial Number: 00000461731745
Encoding: 0100000000000000
Operating number: WSC 12345 123 12345
VCID: 2D06F42E6D10B4D294D-8078
Address 6C: Rear-view camera (J928)
Label file: * None
Part number SW: 4H0 907 428 A, Part number HW: 7P6 907 441 D.
Component: TopView H05 0150
Revision: 11001001 Serial Number: 82330JF0072270
Encoding: 0208000001010000000102000000
ASAM Dataset: EV_CameraSystemTopViewAUDI 006025
ROD: EV_CameraSystemTopViewAUDI_005.rod
Address 6D: Rear hatch (----) Label file: | DRV\4H0-959-107.clb
Part number SW: 4H0 959 107 AB. Part number HW: 4H0 959 107 M.
Component: HDSG Module H11 0043.
Revision: 10011001 Serial Number: 035300072 Data Version Number: 4H0909541E 0022
Encoding: 0210044000
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6E843322A0168FCAED7-803A
Address 6F: Comfort System II (J773) Label file: * None
Part number SW: 4H0 907 412, Part number HW: 4H0 907 412.
Component: ALM H05 0004
Revision: -------- Serial Number: 000000098973 Data Version Number: 4F0000000__ U001
Encoding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 639252167BD432A2729-8036
Address 72: Door electric, high, right (J389) Label file: .4H0-959-795.clb
Component: TSG HR H06 0273
Revision: -------- Serial Number: 0000052263907
Address 81: Selector lever (J587) Label file: 3Y0-927-731.clb
Part number SW: 4H1 927 731 A. Part number HW: 4H1 927 731 A.
Component: GSM-LL H08 0083
Revision: 0L0D5015 Serial Number: SN130116 0172
ASAM Dataset: EV_GSM2x3Mono 001017
ROD: EV_GSM2x3Mono_AU64.rod
Address 85: Camera Control Module (J852)
Label file: | DRV\7P6-907-217.clb
Part number SW: 4G0 907 217 A, HW: 4H0 907 217 A.
Component: DPC-SG H25 0038
Revision: -------- Serial Number: 262130025421000 Data Status Number: 4H0909547E 0033
Encoding: E8060000
ASAM Dataset: EV_OnBoardCameraDPC 001007
ROD: EV_OnBoardCameraDPC.rod
VCID: 26140B024866878A557-8072
Address 88: Multi-contour driver's seat (J873)
Label file: * None
Part number SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00009474314402. Data version number: 4H0909880D 0019.
Encoding: 662FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFront.rod
VCID: 2F3AEE26679CC6C2A61-807A
Address 89: Front passenger multi-contour seat (J872)
Label file: * None
Serial number: 00009474205902. Data version number: 4H0909881D 0019.
Encoding: 262FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Distance Control 2 (J428) Label file: | DRV\4H0-907-561.clb
Part number SW: 4H0 907 541 B, Part number HW: 4H0 907 541.
Component: ACC3 H19 0400
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU64X_002.rod
Address 8E: Image Processing (J851)
Label file: | 4H0-907-107-V2.clb
Part number SW: 4G0 907 107 E, HW: 4H0 907 107.
Component: BV-SG H31 0041
Serial number: 005000121402137. Data version number: 4H0909548G 0020.
Encoding: 01A0BB001111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Left seat belt pretensioner (J854) Label file: 4H0-980-94x-RGS.clb
Part number SW: 4H0 980 945 B, Part number HW: 4H0 980 945 C.
Component: RGS-VL H13 0080
Data record number: 4H0909614C 0003.
Encoding: 0066F609031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313EE85E71A8D032B05-8064
Address 90: Seat belt pretensioner, right side (J855)
Part number SW: 4H0 980 946 B, HW: 4H0 980 946 C.
Component: RGS-VR H13 0080
Data record number: 4H0909615C 0003.
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323CE75274AEEB2AC9F-8066
End -------- (Duration: 03:13, Battery voltage start/end: 13.8V/14.7V) ---------
Log-A-MS 537-WAUZZZ4H2DN026221-257812km-Redjag Reset.txt
 File name:  Log-A-MS 537-WAUZZZ4H2DN026221-257812km-Redjag Reset.txt
 File size:  25.74 KB
 Downloaded:  558 times
Fehler sind dafür da nur einmal gemacht zu werden
Translated on 14-07-2026, 0:43.
Post19-03-2024, 10:55    Subject: Audi A8: Start-stop system doesn't always work Quote
In the engine control unit's diagnostic data, there should be something that indicates whether or not the start-stop system is active, and potentially why it might not be working.
For me, the level of discomfort was never high enough to warrant checking that.
Common causes include a DPF clogged with ash, or issues with the DPF regeneration process (during which the start-stop system is disabled).
With that mileage, a weak battery with low voltage is just as likely to be the cause.
Translated on 14-07-2026, 0:44.
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.6 TDI: No dual-mass flywheel with start-stop function Transmission, Chassis, Body & Interior
No new posts Cruise Control Not Working? Troubleshooting Guide. Diesel Engine Technology
No new posts 1Z Still Not Working: Troubleshooting Guide Diesel Engine Technology
This topic is locked, you cannot edit or reply. LMM Replacement at Audi: Not Possible? Diesel Engine Technology
