Mercedes Vito 639 100kW Error Code P2600
berger20000
Post14-03-2024, 14:51    Subject: Mercedes Vito 639 100kW Error Code P2600 Quote
Hello.
We are having a problem with a Mercedes Vito 1313 BRJ, where the engine check light keeps coming on with the following error:
P2600: Coolant pump switching valve circuit fault.
We've already replaced the electric thermostat, and we haven't found the auxiliary pump yet!
Has anyone ever experienced this before?
Michael.
 File size:  337.99 KB
 Viewed:  856 times
Audi A4 B6 2.5TDI Quattro
Skoda Superb 4x4 TDI CR2
Polo 6N 1.8T AUQ
Translated on 07-07-2026, 20:49.
Post14-03-2024, 18:55    Subject: Re: Mercedes Vito 639 100kW Error Code P2600 Quote
berger20000 wrote:
P2600 Coolant pump switching valve circuit malfunction.
In your case, I would check the wiring harness, all the way up to the control unit, for signs of damage caused by rodents or chafing. Also, make sure that all the pins in the connectors are making contact and that none of them have become dislodged.
Translated on 07-07-2026, 20:50.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber likes this.
Post14-03-2024, 19:23    Subject: Mercedes Vito 639 100kW Error Code P2600 Quote
Hello Michael,
The connector for the switching valve (Y19/10) is located under the engine cover. The wires in the connector are often brittle. Have you checked the connector?
The power supply comes from the engine control unit, pin 31, and the other wire connects to pin 9 of the glow plug control unit.
Michael.
Translated on 07-07-2026, 20:51.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0148 - Fuel Supply Malfunction General Tips
No new posts Mercedes Vito 10c: Parts for 1997/98 Models Diesel Engine Technology
No new posts Seatbelt Pretensioner Explodes in Mercedes Vito Transmission, Chassis, Body & Interior
No new posts Differences between 2.0 TDI engines with 100kW and 103kW ... Diesel Engine Technology
No new posts Mercedes-Benz Vito, manufactured in 2012 On-Board Diagnostics (OBD)
