Service reset failed on Golf Sportsvan 2016
stolley
Karma: +38 / -1   Thank you, like it!
Post10-02-2024, 11:44    Subject: Service reset failed on Golf Sportsvan 2016 Quote
Hello everyone,
Today, I tried to postpone the service appointment for my Golf Sportsvan.
However, I am receiving a message indicating that no information is available regarding automatic resets for the specific control unit. Attached is a Screenshot, and below is a log of the error memory.
I can hardly imagine that the automatic parking feature would work on my 2008 Polo 9N3 but not on a 2016 Golf. It's probably just a setting issue.
Or do I actually have to do that manually?
Saturday, February 10, 2024, 2:53:27:25065
VCDS, a Windows-based VAG/VAS emulator, runs on Windows XP x86.
VCDS Version: RKS 23.11.0.1
Data as of: 20240123 DS351.0
http://shop.dieselschrauber.org/en
Vehicle Identification Number: WVWZZZAUZGW5643XX
License plate: A-
Mileage: 124,595 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
Vehicle Identification Number: WVWZZZAUZGW5643XX Mileage: 124595 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
10-Parking Assist 2 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnostic interface -- Status: Error 0010.
42-T voltage regulator. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-core electrical. Front passenger seat. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module (J623-CXXB) Label file: . DRV\04L-907-309-V1.clb
Part number SW: 04L 906 056 CM, HW: 04L 907 445 B.
Part: R4 1.6L TDI H06 9471
Revision: 22004001
Encoding: 0111401243241D092000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI03004L906056CM 004010
ROD: EV_ECM16TDI03004L906056_004.rod
VCID: 7AFDC540FDBEB0418C-802E
VINID: 9E69EAAAA465A979C51840C40839845B42
No error codes found.
Readiness: Not available.
Address 03: Brake Electronics (J104)
Label file: DRV\5Q0-907-379-IPB-V1.clb
Part number SW: 3Q0 907 379 AF, HW: 3Q0 907 379 F.
Component: ESC H42 0625
Revision: 00000000 Serial Number: 63165000002562
Encoding: 03FA62A124268970077A060441C525C0462491E06082A4F310400078C002
Operating number: WSC 131071 1023 2097151
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7EF5C950E1969C61B0-802A
Address 08: Climate Control/Heater (J255) Label file:| DRV\5G0-907-044.clb
Part number SW: 5G0 907 044 BD Hardware: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08 Data version number: 0000
Encoding: 08020104202100011005000000101002
Operating number: WSC 39098 004 1048576
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6ADDF5008D1E00C17C-803E
Control unit for fresh air blowers (front).
Refrigerant pressure/refrigerant temperature sensors:
Air quality sensor:
Address 09: Central Electronics (J519) Label file:| 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 086 AK. Part number HW: 5Q0 937 086 AK.
Part: BCM PQ37BOSCH 028 0162
Revision: --------
Serial number: 86582311152745
Data version number: V03935222KD 0001
Encoding: 00000846C24100DB4BE44000001C07081000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 0303B8A48A74F189DF-8056
Control unit for windshield wiper motor:
Subsystem 1 - Part number SW: 517 955 119 HW: 517 955 119 Label file: DRV\5QX-955-119-V1.CLB
Part: WWS 151028 042 0596
Serial number: 151110151429
Encoding: 0E4DDD
Humidity source: indoors:
Subsystem 2 - Part number SW: 8U0 955 559 HW: 8U0 955 559 Label file: DRV\8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 71281002
4 error codes found:
5130 - Front turn signal light, left.
B11E8 15 [00001000] - Short circuit or open circuit after the positive terminal.
Sporadically - confirmed - checked since last deletion.
6922 - Headlight low beam lamp, right side.
B1218 15 [00001000] - Interruption/short circuit after positive terminal.
204290 - Radio key 1.
B1479 18 [00001000] - Current too high.
Environmental conditions:
Error priority: 4
Error frequency: 1
Lost Count: 40
Mileage: 122,025 km
Date: 2023.12.11
Time: 12:06:26
Status terminal 15: off.
Status terminal 50: off.
CAN-Bus_active: on
Status of brake light switch (hardware): off.
Status brake light switch (CAN): off.
certainly
Standing light: not activated.
Automatic headlight control: not activated.
Low beam: not activated.
Left parking light: not activated.
Right parking light: not activated.
last_wakeup: valid radio telegram.
Voltage: 12.1 V
Outdoor temperature: 8.5 °C
132363 - Supply voltage for terminal 30 (left side).
B140D 13 [00001000] - Interruption.
Address 10: Parking Assist 2 (J446) Label file:| DRV\5Q0-919-294.clb
Part number SW: 5Q0 919 294 K, HW: 5Q0 919 294 A.
Component: PARKING ASSIST 8K H03 0054.
Revision: --------
Serial number: 39391532703676
Data version number: V03935229MQ 0001
Encoding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 438378A4CAF431899F-8016
Address 13: Distance control (J428) Label file:| 5Q0-907-572-V1.clb
Part number SW: 5Q0 907 572 F. Hardware: 5Q0 907 572 F.
Part: ACC Bosch MQB H05 0400
Serial number: 20111503273778
Data version number: 5g0114v____ 1027
Encoding: 00000100FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 3A7D0540BD3E7041CC-806E
Address 15: Airbag (J234) Label file:| DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 D, HW: 5Q0 959 655 D.
Part: Airbag VW20 015 0388
Serial number: 003F6R197RHQ. Data version number: 5GP003V____0023.
Encoding: 98CCC000000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 418F72ACD0E823998D-8014
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: ----------- HW: 480 001 011 15
Component: SideSensor_Df 001 0887
Serial number: 35767000000BD6A87715
Encoding: 2D2D2D
Crash sensor for the side airbag, passenger side:
Subsystem 2 - Part number: SW: ----------- HW: 480 001 011 15
Component: SideSensor_Pf 001 0887
Serial number: 358670000002FB4D7713
Encoding: 2D2D2D
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: ----------- HW: 480 401 711 15
Part: SideSensor_Dr 001 6149
Serial number: 35165029F1E34434B2FL
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side:
Subsystem 4 - Part number: SW: ----------- HW: 480 401 711 15
Component: SideSensor_Pr 001 6149
Serial number: 35265029B1E34434233+
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number SW: ----------- HW: 480 401 611 15
Component: FrontSensor_D 001 6149
Serial number: 3556502A31E34435325/
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J527) Label file:| DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 507 FT, HW: 5Q0 953 549 F.
Component: Steering. Module 003 0120.
Revision: -------- Serial Number: 23111504220828
Encoding: 0400
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 0D179E9CDC30B7F9B9-8058
Address 17: Terminal block insert (J285) icon_neutral.gif Label file: DRV\5G0-920-XXX-17.clb-SRI3
Part number SW: 517 920 751 A, Hardware: 517 920 751 A.
Part: KOMBI 302 6420
Encoding: 07A402002380000801886A011400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 1625F1F0E9E6742108-8042
Address 19: Diagnostic interface (J533) Label file:| DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AJ, HW: 5Q0 907 530 F.
Part: GW MQB High 128 1244
Revision: --------
Serial Number: 0004235828
Data Version Number: 5G0067V____ 2407
Encoding: 030100041F087300FB000248080F000100010500000000000000000000000
GVL: 01543C0000000000400C80000000480000000000000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 79FFDA4CF8B8BB5985-802C
Generator:
Steering wheel control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 5G0 959 442 J HW: 5G0 959 442 J Label file: DRV\3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29150002309380025473.
Encoding: 28FFFF
Battery monitoring control unit:
Subsystem 3 - Part number SW: 5Q0 915 181 G, HW: 5Q0 915 181 G.
Part: J367-BDM Hella H04 8050
Serial number: 0771508403
"1 error found:"
66052 - Infotainment CAN.
U0065 00 [00001000] - No communication.
[New feature!] Extended UDS error code information is only supported by current hardware generations.
Error priority: 2.
Error frequency: 2
Lost Count: 13
Mileage: 124,286 km
Date: 2024.02.01
Time: 16:59:12
Supply voltage, terminal 30: 12.4 V.
Terminal 15: off.
Address 42: Turntable electrical. Driver (J386) Label file:| 5QX-959-X93-42.clb
Part number SW: 5Q0 959 593 E, HW: 5Q0 959 593 B.
Part number: TSG FS 020 0041.
Serial number: 290915BIR02096
Data version number: 5GP222v____ 0006
Encoding: 00310320D000040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Rear driver's side door hinge.
Subsystem 1 - Part number SW: 5Q0 959 811 HW: 5Q0 959 811 Label file: DRV\5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000008160551
Encoding: 110000
Address 44: Steering Assist (J500) Label file:| DRV\5Q0-909-143.clb
Part number SW: 5Q0 909 143 K, HW: 5Q0 909 143 E.
Part: MQB_PP_APA 204 2033
Revision: 00000000 Serial Number: 0000511524 Data Version Number: V03935223ZW 0001
Encoding: 01000010005000
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3B730044B2044949D7-806E
Address 52: Power supply. Co-driver. (J387) Label file:| 5QX-959-X92-52.clb
Part number SW: 5Q0 959 592 E, HW: 5Q0 959 592 B.
Part number: TSG BFS 020 0041.
Serial number: 021015BJ108868
Data version number: 5GP157v____ 0006
Encoding: 00310120DE00040000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428D7DA0D5EE388194-8016
Rear passenger side airbag module:
Subsystem 1 - Part number SW: 5Q0 959 812 HW: 5Q0 959 812 Label file: DRV\5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000008199978
Encoding: 090000
Address 5F: Information selection. I (J794) Label file:| 5G0-035-MIB-STD2.clb
Part number SW: 3Q0 035 846 Hardware number: 3Q0 035 846
Part number: MU-S-N-ER 820 0627
Serial Number: Data Version Number: 5G0CV1v____ 0001
Encoding: 02730901FF00000051110001000808001F01008401200100CF
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6ED5F910B1F6ECE120-803A
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 3G0 919 605 D, HW: 3G0 919 605 D.
Part: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R3181904
Data carriers:
Subsystem 2 - Part number SW: V03 959 820 CL HW: -----------
Component: ECE DL2 23/24 --- 2010
Serial number: --------------------
End----------------------------(Duration: 04:22)-----------------------------
LG
Volker.
 File size:  1.41 MB
 Viewed:  512 times
Karma: +807 / -0   Thank you, like it!
stolley likes this.
Post10-02-2024, 14:24    Subject: Service reset failed on Golf Sportsvan 2016 Quote
If you read the Screenshot I posted, you'll find the attached instructions for resetting the service via UDS.
Servicerueckstellung-VCDS-UDS.pdf
 File name:  Servicerueckstellung-VCDS-UDS.pdf
 File size:  900.01 KB
 Downloaded:  1485 times
stolley
Post10-02-2024, 20:53    Subject: Service reset failed on Golf Sportsvan 2016 Quote
Thank you!
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Service Interval Display / Maintenance Indicator Technical Data
No new posts CNG service reset, gas tank Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Adjustment Fails: What Went Wrong? On-Board Diagnostics (OBD)
No new posts Golf 7 Service: Reset Maintenance Light Diesel Engine Technology
No new posts VCDS HEX-V2 - Service reminder reset for Golf VII On-Board Diagnostics (OBD)
No new posts A6 Coding Error: Dashboard Malfunction (2005) On-Board Diagnostics (OBD)
