Were there AFN models with a shut-off valve?
Post30-06-2005, 8:51    Subject: Were there AFN models with a shut-off valve? Quote
The AFN engine was fitted with both 028 and 038 engine control units (ECUs) because it was used in the Passat 3B for a long period.
Did it also come with a bypass valve, meaning the attached EGR unit, and with the 038 intake manifold, which has the threads for the EGR unit?
Post06-03-2024, 23:00    Subject: Re: Were there AFN models with a shut-off valve? Quote
I am not aware of any AFN engines with a bypass valve. AHF and ASV engines have a pneumatically controlled bypass valve, as did early PD-TDI engines. Later PD-TDI and CR-TDI engines have an electric throttle valve.
No new posts 1Z with shut-off valve Diesel Engine Technology
No new posts 028 906 021 DF und Abstellklappe? On-Board Diagnostics (OBD)
No new posts Abstellklappe nachbauen Diesel Engine Technology
No new posts Ansteuerung Abstellklappe Diesel Engine Technology
