1.4 TSI CTHA -- Air leaks, how much are you experiencing?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
Ste.Bo
Karma: +89 / -0   Thank you, like it!
dieselschrauber likes this.
Post17-01-2024, 21:46    Subject: 1.4 TSI CTHA -- Air leaks, how much are you experiencing? Quote
Hello everyone,
I would like to know what the typical values are for leak-off air during idle for a 1.4 TSI CTHA engine (with both a supercharger and a turbocharger).
Depending on the temperature, I'm getting between 2.8 and 4.3 kg/hour, and I now suspect that there are no leaks anywhere. Am I chasing a ghost?
There is no error.
I only replaced the obviously leaky charger hose seal and the faulty recirculation valve, and now I want to check [something]. The values are significant, but I don't notice any real difference right now.
Since gasoline cars aren't really my thing, maybe someone here knows more about them.
Bo.
Ste.Bo
Post10-02-2024, 18:29    Subject: 1.4 TSI CTHA -- Air leaks, how much are you experiencing? Quote
The check valve on the fuel tank vent (directly connected to the intake manifold after the throttle body) was defective.
Air leakage after replacement remains within a negligible range.
Post10-02-2024, 18:31    Subject: 1.4 TSI CTHA -- Air leaks, how much are you experiencing? Quote
No new posts 1.4 TSI CTHA - Fuel consumption figures Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air leak in the intake system On-Board Diagnostics (OBD)
No new posts wieviel ccm hat der AKU ? Diesel Engine Technology
No new posts KGE: How much oil leakage is normal? Diesel Engine Technology
No new posts Turbolader wieviel druck ?? Diesel Engine Technology
