Read ash data
stolley
Karma: +38 / -1   Thank you, like it!
Post02-04-2024, 13:10    Subject: Read ash data Quote
Hello everyone,
I would like to read the ash mass of the DPF in my Golf Sportsvan.
However, the button for the diagnostic data display is gray in the engine control unit.
Can anyone help me with that?
Thank you very much!
Saturday, February 10, 2024, 2:53:27:25065
VCDS, a Windows-based VAG/VAS emulator, runs on Windows XP x86.
VCDS Version: RKS 23.11.0.1
Data as of: 20240123 DS351.0
Vehicle Identification Number: WVWZZZAUZGW5643XX License Plate:
Mileage: 124,595 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
Vehicle Identification Number: WVWZZZAUZGW5643XX Mileage: 124595 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: Error 0010.
10-Parking Assist 2 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnostic interface -- Status: Error 0010.
42-T voltage regulator. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-core electrical. Front passenger seat. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
http://shop.dieselschrauber.org/en
Post02-04-2024, 13:24    Subject: Read ash data Quote
This is a 2016 model year. There are no more measurement blocks available; only extended measurement data. You have to look there.
It's possible that the HEX+CAN interface is no longer fully functional for that model year, which is why you're seeing errors, and that's why I'm asking about the car scan.
stolley
Post02-04-2024, 13:49    Subject: Read ash data Quote
It's possible that the HEX+CAN interface is not fully functional for that model year, which is why there are errors, and that's why the question about the Autoscan.
Okay, you're welcome!
I have to admit that the LOG actually has nothing to do with my question; I just included it to provide the necessary data.
Okay, let's check the extended measurement data...
stolley
dieselschrauber likes this.
Post02-04-2024, 17:32    Subject: Read ash data Quote
Okay, it actually worked with the extended measurement blocks!
Thank you for the information!
 Read ash data
 File size:  411.93 KB
 Viewed:  365 times
No new posts Touran: Read DPF Ash Mass with VCDS (BLS) Diesel Engine Technology
No new posts Reset ash mass to 0 On-Board Diagnostics (OBD)
No new posts Abgleich Aschemasse On-Board Diagnostics (OBD)
No new posts Aschemasse und Kilometerleistung Diesel Engine Technology
