Hello guys,
"Does anyone happen to be familiar with this topic? I was planning to dynamically adjust my fuel injection pump today. I've already obtained the adjustment values (target values). I went into the engine control unit, measurement block 4, and so far everything seemed to be working, but the injection start timing is showing 0°, and adjusting it mechanically doesn't change anything! Could it be that the pump is somehow faulty?" Or maybe it was because I only had a coolant temperature of 62° (unfortunately, I can't get it any higher with this weather).
AL
