Error codes and error messages in the cockpit
derdoode
Post14-04-2024, 11:57    Subject: Error codes and error messages in the cockpit Quote
Today, I had another diagnostic session to try and identify the cause of the intermittent, wave-like acceleration issue.
And I was overjoyed as the yellow engine warning light came on during the boat trip, and I thought, "Now I've finally caught you."
But that's nonsense:
When I read the error codes, I discovered that the error log had recorded the error three days ago.
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible signal.
Environmental conditions:
Error status: 01100000
Error priority: 2
Error frequency: 1
Lost Counter: 255
Mileage: 214,500 km
Time: 0
Date: 2024.04.11
Time: 18:35:51
Since I couldn't find a similar question in the forum, I'm posting it here. Error codes and error messages don't necessarily have to appear at the same time, do they?
I hope the CSV log files will provide me with more helpful information.
derdoode
dieselschrauber likes this.
Post15-04-2024, 8:15    Subject: Error codes and error messages in the cockpit; solved! Quote
Meanwhile, I know that the message in the cockpit doesn't appear late, but it flashes because the error recurs.
Ronald.
Post15-04-2024, 9:44    Subject: Error codes and error messages in the cockpit Quote
Hello Ronald,
Normally, the error message and the warning symbol on the dashboard appear at the same time. However, I've experienced a situation where the warning symbol remained illuminated even after the error had cleared (it was a message related to the bulb monitoring system). It was quite frustrating because the issue occurred sporadically and it wasn't immediately clear what the problem was (the lamp had a loose connection).
There's no rule without an exception. X
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Golf 4 Dashboard: Old vs. New Transmission, Chassis, Body & Interior
No new posts Turbocharger Error: Boost Control Issue On-Board Diagnostics (OBD)
No new posts Alarm System Error: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Error Message Removed: Kat's Solution On-Board Diagnostics (OBD)
