Update for VCDS German Version 24.07.0
Post31-07-2024, 10:18    Subject: Update for VCDS German Version 24.07.0 Quote
VCDS 24.07.0 Update
The new German VCDS version 24.07.0 with updated data status 20240715 is available.
In your customer account under
https://shop.dieselschrauber.org/en/account.php
Find the latest installation packages for your VCDS diagnostic tool to download.
Changes:
• New: Support for new/upcoming models
• New: TDI Graph support for additional engine variants
• Improvement: Interface configuration, hardware detection revised
• Improvement: Diagnostic module for ASAM/UDS (parameter transfer) extended
• Improvement: Revised default settings for ASAM/UDS (parameter transfer)
• Improvement: ASAM/ODX-Mapping for Bentley models revised
• Improvement: Address list revised
• Improvement: Translation and error messages revised
• Improvement: LCode coding assistant plugin updated
• Improvement: Revised Configuration and Update Program (VCIConfig) for HEX-NET & HEX-V2
• Improvement: The auto-scan functionality was limited under certain circumstances.
• Documentation for tax equipment (label files and ODX/ASAM data files) has been expanded/updated
Best regards, Rainer
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Bosch ESP 5.3: Error Codes & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and possible causes for Bosch ABS Version 5.0... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Update for VCDS German version 25.3.1, multi-brand diagno... On-Board Diagnostics (OBD)
No new posts VCDS Plugins: German Language Guide On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 3-Fin Version On-Board Diagnostics (OBD)
