1.9 TDI ASZ Manual Transmission - Slight Idle Jerk
Go to page: 1, 2  Next
kiter
2015 Seat Leon
Post18-03-2024, 11:43    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Our Seat Ibiza ASZ TDI with 280,000 km has a slight hesitation when idling.
When the clutch is depressed, the jerking almost completely disappears. It's probably due to the electrical coupling switch.
"It sends a signal to the MSG and apparently changes something about the injection process without altering the engine speed?"
AGR LMM sensors were newly installed about a year ago (all original parts).
Okay, so if the alternator has to provide more power at idle (e.g., for the rear window heater or an electric auxiliary heater), it tends to fluctuate or vibrate a bit more.
Could it also be due to the Lima free-running feature?
I replaced this one 10 years ago because it was making noises.
Karma: +647 / -0   Thank you, like it!
dieselschrauber and Ste.Bo likes this.
Post18-03-2024, 19:35    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
At my daughter's allergy center, the underlying cause was identified as ZMS.
kiter
2015 Seat Leon
Post19-03-2024, 7:31    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Thank you, Rüdi. I had it replaced by Seat at approximately 240,000 km.
Post19-03-2024, 9:24    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
One possibility would be one or more faulty fuel injectors. Therefore, check the idle speed control or the individual cylinder corrections. You should specifically look at the effects related to load changes.
You've already mentioned the second one, which is the alternator's free-running mode.
kiter
2015 Seat Leon
Post19-03-2024, 9:30    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Thank you, Herbert.
Can the free-running clutch be checked effectively?
He hasn't made any noise so far.
All the PDE elements, etc., are still original.
If that were the case, you would definitely need to overhaul the cylinder head, including the camshafts and related components.
I'll start by looking at the idle speed control.
Post19-03-2024, 9:56    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Is it possible to meaningfully check the freewheel?
Remove the belt and check the pulley by hand (rotate it against the rotor). In one direction, it must be able to rotate freely.
kiter
2015 Seat Leon
dieselschrauber and Herbert likes this.
Post19-03-2024, 10:13    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Then I'll remove the belt and let the engine idle without the alternator.
I'll let you know tonight what the results are.
Ste.Bo likes this.
Post19-03-2024, 14:41    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Possibly, the PD cable harness is also the cause.
kiter
2015 Seat Leon
Post19-03-2024, 15:34    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
The wiring harness is still original. Since the slight hesitation only occurs when idling, I would rule that out for now.
kiter
2015 Seat Leon
Post19-03-2024, 18:01    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Herbert, the idle speed control shows readings of -0.00 to -0.12 for cylinders 1-3, while cylinder 4 fluctuates between +0.19 and +0.26.
Unfortunately, it's barely shaking today.
The belt came off without any modifications, and the freewheel mechanism is working.
Can the idle speed be easily increased?
dieselschrauber likes this.
Post19-03-2024, 21:49    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
What happens without an alternator when you add a load? Light, climate control, rear window, fan, ...
What does the LLR indicate?
Ste.Bo
Karma: +90 / -0   Thank you, like it!
Post19-03-2024, 22:03    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
"Mine only lasted 18,000 km after the replacement. Audi had to replace it with a new one at their own expense after 9 months." I have no idea what mistakes they made during the installation.
kiter
2015 Seat Leon
Post20-03-2024, 7:58    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Herbert Riemen is at it again icon_smile.gif.
Do belt-driven e-bikes offer any advantages?
I increased the idle speed from 903 to 924 RPM.
For the past 20 years, the car has consistently been fueled with Aral gasoline.
Does it make any difference to use Ultimate gasoline or to add fuel injector cleaner to the tank?
Wouldn't it be a good idea to have the common rail injectors (check/replace) resealed and have the injector control cables replaced at 280,000 km?
Unfortunately, the driving profile has been mostly short distances for the past 7 years (twice 20 km).
The Ibiza is rust-free and in excellent condition with regards to maintenance.
Post20-03-2024, 9:48    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Does it make any difference to add Ultimate gasoline or fuel injector cleaner to the tank?
"Stuttering" is very subjective; could you make a video where we can hear it?
Misfires can also occur if the EGR rate is too high, which can happen if the mass airflow sensor (MAF) measures too much air. Does changing the specified LMM (likely referring to a Mass Air Flow sensor) affect the engine's performance?
Ste.Bo
Post20-03-2024, 9:50    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
I had two cars for 16 years. Here's the translation:
"We have one car that's a real gas guzzler, driven about 40,000-60,000 km per year on the highway, and family cars that are used 70% of the time for short trips with the kids, covering approximately 15,000 km per year."
I have a feeling that the latter have greatly benefited from me adding half a can of "LIQUI MOLY Pro-Line Diesel System Cleaner" twice a year.
By the way, my 3.0 TDI that I bought used also has the same problem.
kiter
2015 Seat Leon
Post20-03-2024, 9:55    Subject: 1.9 TDI ASZ Manual Transmission - Slight Idle Jerk Quote
Hello Rainer,
I replaced the LMM (lambda sensor) and AGR (exhaust gas recirculation) valve 2-3 years ago (always with original parts).
I will unplug the LMM connector tonight and report back.
The shaking is almost impossible to capture on video because it's only barely noticeable. I'm still trying.
The vehicle always starts perfectly and immediately, even after two weeks of inactivity.
The intake manifold has never been cleaned, and the EGR system is fully functional, just like it was from the factory.
No new posts Document A4 8E Diesel with 5-speed manual transmission: O... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MWB 10 & 11 - A3 1.9 TDI Manual Upload
No new posts Log 3, 8, 11 Audi A6 2.5 TDI BDG, Manual Transmission (Or... Upload
No new posts Golf 7 GTD manual transmission has a slight leak Transmission, Chassis, Body & Interior
No new posts Audi A6 C5 Allroad transmission conversion: from Multitro... Gasoline Engine Technology
