Rejected by the control unit, VCDS
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post11-12-2024, 7:17    Subject: Rejected by the control unit, VCDS Quote
Hello everyone in the forum,
Basically, I can select whatever I want, but I'm only getting error messages from the control unit. What can I do to get it working again? Best regards, Wolfgang.
Back to top Profile PM Email
dieselschrauber likes this.
Post11-12-2024, 10:27    Subject: Rejected by the control unit, VCDS Quote
Hi Wolfgang,
"I have a German car that is having a problem with the transmission." What can I do?
Do you understand?
Both requests are missing a significant amount of crucial information.
At your place:
- Vehicle / Car scan.
- which ECU?
- Which login are you using?
- What is the goal?
Guste.
Schmierpfote
Post11-12-2024, 16:26    Subject: Rejected by the steering device Quote
Hello Guste,
Thank you for the help. I tried to start the "SCR efficiency test" via motor electronics and basic settings, but no matter what I select in the dropdown list, I get an error. Extended measurements, etc. are working fine.
My VCDS software doesn't like Windows 11 or the HP laptop.
Log-HX-WV2ZZZ7HZHH091255-316430km-scan.txt
 File name:  Log-HX-WV2ZZZ7HZHH091255-316430km-scan.txt
 File size:  12.95 KB
 Downloaded:  1166 times
Post11-12-2024, 18:01    Subject: Rejected by the control unit, VCDS Quote
Okay.
It's been a long time since I last adjusted the basic settings.
Is a login prompt displayed when you click on the "Login" button?
guste100 wrote:
- Which login is being used?
Schmierpfote
Post11-12-2024, 18:11    Subject: Rejected by the control unit, VCDS Quote
Hello Guste, select the engine control unit, choose the basic settings, and then select from the dropdown menu what you want to check.
Press "Start" to begin. I'm getting an error, and no suggestions are being offered.
Post12-12-2024, 17:03    Subject: Rejected by the control unit, VCDS Quote
Hello Wolfgang,
I have to admit that I'm starting to lose interest, as you're not providing the information I'm looking for. Therefore, here's one last attempt:
guste100 wrote:
Is a login prompt offered to you when you click on "Login"?
Please go to the MSG page, and then click on "Login" instead of "Reset to Default."
If none of that works, I'm afraid I'm completely clueless.
Schmierpfote
Post12-12-2024, 18:12    Subject: Rejected by the control unit Quote
Hello Guste,
There's a guide in the forum by Rainer titled "Calibrating the NOX DPF sensor." As I mentioned, select "Check SCR efficiency" from the dropdown menu and press "Start." Now the VCDS program is running. I'm getting an error message. I will go to the MSG this weekend, as you wrote, and then to Login.
I will report, greetings Wolfgang.
Post12-12-2024, 18:40    Subject: Rejected by the control unit, VCDS Quote
I see that the data is not current; please update VCDS. You might be referring to a test setup or an intermediate result.
https://shop.dieselschrauber.org/en/support-downloads.php
Schmierpfote
Post12-12-2024, 18:43    Subject: Rejected by the steering device Quote
Thank you, Rainer.
Greetings, Wolfgang.
Schmierpfote
Post15-12-2024, 15:15    Subject: Rejected by the steering device Quote
Hello Rainer and Guste,
Thank you for your help.
No error codes found.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Comfort System Module 46 - Version 20.4.2 On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
