Golf 7: Turning lights not working
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +2 / -2   Thank you, like it!
Post13-05-2025, 10:28    Subject: Golf 7: Turning lights not working Quote
Good day.
I have a Golf 7 where the fog light and turn signal light are combined into one unit. The fog lights themselves are working fine, but the turn signal function is not working. What could be the cause?
Who can help? Thank you for any response.
Translated on 14-07-2026, 0:06.
dieselschrauber likes this.
Post13-05-2025, 12:51    Subject: Golf 7: Turning lights not working Quote
If the fog lights are generally working, then either the cornering light function has been disabled, or there is a fault.
Since you got VCDS from here, the first questions are:
- Error memory read?
- Encoding checked?
Translated on 14-07-2026, 0:07.
Post14-05-2025, 8:49    Subject: Golf 7: Turning lights not working Quote
The cornering light in the G7 is integrated into the main headlight.
https://www.youtube.com/watch?v=93xaloVFcEQ
In the Skoda Octavia, it is implemented via the fog lights.
Translated on 14-07-2026, 0:08.
Post14-05-2025, 10:48    Subject: Golf 7: Turning lights not working Quote
Bertil wrote:
Das Abbiegelicht im G7 ist im Hauptscheinwerfer integriert.
That's not generally true. As always: it depends...
It's located in the headlight with xenon bulbs.
For halogen bulbs, it's in the fog lights (at least in my Golf 7 station wagon).
Since the person who started the thread mentioned that it was integrated in their NSW (New South Wales) system, I initially believed them. However, it's definitely a good idea for them to clarify whether they actually have halogen lights. Otherwise, they might be looking in the wrong place.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 14-07-2026, 0:09.
Post14-05-2025, 11:07    Subject: Golf 7: Turning lights not working Quote
Translated on 14-07-2026, 0:10.
Post14-05-2025, 20:31    Subject: Golf 7: Turning lights not working Quote
In my G7 wagon, which had H7 projectors installed five years ago, it was definitely in the main headlight.
dieselschrauber and Bertil likes this.
Post15-05-2025, 9:23    Subject: Golf 7: Turning lights not working Quote
Now you've surprised me, and I took a look at the spare parts catalog to see what's available (as an example for my 2013 model year).
PR-8ID: I have halogen double headlights. The cornering light is integrated via the fog lights. The daytime running lights are implemented using a dual-filament halogen headlight within the high beam reflector.
PR-8IG: Headlights for gas discharge lamp (simple xenon). Probably has halogen daytime running lights. I have no idea where the cornering light is located. I suspect it's also integrated into the main headlight unit.
PR-8IM: Headlights with cornering lights and LED daytime running lights (you probably already have those). These likely feature projector lenses and turning lights integrated into the main headlight unit.
PR-8IP: Includes xenon headlights with dynamic high beam (DLA - dynamic light assist) and LED daytime running lights. I suspect there's also a cornering light integrated into the main headlight, but I'm not certain.
PR-8IT: LED Headlights.
So, there are already significantly more variations available from the factory than I was aware of. And that makes it clear that the person who created this should really post a photo of their headlight and the car scan/coding information. Unfortunately, we haven't heard from them since.
Translated on 14-07-2026, 0:12.
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Window doesn't close Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, from 5/99, Rear door lock not working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Problems: Troubleshooting & Fixes Diesel Engine Technology
No new posts ABS/EDS vom Golf 3 VR6 funktioniert nicht (Umbau) On-Board Diagnostics (OBD)
No new posts VW Golf 2 Heater Not Working? Troubleshooting Diesel Engine Technology
No new posts Cruise control not working Diesel Engine Technology
