Touareg: Intermittent Jerking - 4.2 TDI Fix
JohnRambo1980
Post29-06-2025, 8:49    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
Hello everyone,
I've been experiencing intermittent problems with my Touareg 7P 4.2 TDI for weeks.
The car occasionally jerks after gear changes within the RPM range of 1500 to 2000 RPM. It's a single jolt occurring approximately 1 second after the gear change, but it happens sporadically.
It is usually more pronounced when the engine is cold.
When accelerating quickly, you don't notice any jolts.
It feels like there's a brief interruption right after the gear change.
A transmission flush has already been performed, the mass airflow sensor (MAF) has been replaced, the EGR valves have been replaced, the fuel pre-pump has been replaced, and the intake manifold has been cleaned.
Best regards, Raimund.
There are no error codes in the engine control unit (ECU) or transmission control unit (TCU).
Does anyone have a suggestion for something I could check or some help they can offer?
I did some logging runs related to throttle position and fuel injection deviations.
Perhaps someone would like to review the LOG trips.
I placed a marker after the jump in the first file.
26.06.2025 2.csv
 File name:  26.06.2025 2.csv
 File size:  4.68 KB
 Downloaded:  308 times
26.06.2025 1.csv
 Logfahrt
Logfahrt
 File name:  26.06.2025 1.csv
 File size:  68.73 KB
 Downloaded:  279 times
Log-WVGZZZ7PZCD005639-221123km.txt
 File name:  Log-WVGZZZ7PZCD005639-221123km.txt
 File size:  25.84 KB
 Downloaded:  274 times
Translated on 24-07-2026, 23:03.
Post29-06-2025, 19:08    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
How did the intermittent jerking/stuttering occur?
Is this something that happens automatically, or only after a modification or service to the vehicle?
Translated on 24-07-2026, 23:05.
JohnRambo1980
Post29-06-2025, 19:27    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
Hello Reiner,
A few weeks ago, I replaced the AGR valves.
"There was an error: insufficient flow."
VW has installed the diesel update.
The occasional jerking had been present sporadically before.
However, it has become more frequent over the past two weeks.
Translated on 24-07-2026, 23:06.
JohnRambo1980
Post09-07-2025, 7:19    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
Hello.
Can someone help me with something?
Who has experience with this engine?
Could the swirl flaps be causing the problem?
Translated on 24-07-2026, 23:07.
Post09-07-2025, 20:04    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
I'm not familiar with this engine, but if the swirl flaps are controlled pneumatically, I could imagine occasional malfunctions.
The only solution is to obtain a Service Security Password (SSP) for the engine, open the hood, and inspect it. If there are pneumatic valve actuators, check for leaks in the diaphragms of the actuators and in the hoses connected to them. Of course, the solenoid valve that controls these actuators could also be internally blocked.
Translated on 24-07-2026, 23:08.
JohnRambo1980
Post10-07-2025, 19:49    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
The swirl flaps are electrically controlled.
I once checked the rail pressure calibration points and quantity deviations.
Quantity deviations in the cold operating state after engine start and when the engine is warm.
Could someone please review and evaluate these values?
 Mengenabweichung bei warmen Motor
 File size:  735.42 KB
 Viewed:  193 times
 Mengenabweichung bei kaltem Motor
 File size:  698.59 KB
 Viewed:  212 times
 Raildruckkalibrierpunkte 3
 File size:  983.96 KB
 Viewed:  172 times
 Raildruckkalibrierpunkte 2
 File size:  1.18 MB
 Viewed:  200 times
 Raildruckkalibrierpunkte 1
 File size:  721.97 KB
 Viewed:  190 times
Translated on 24-07-2026, 23:09.
Post13-07-2025, 21:43    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
The fuel injection volume deviations are very good.
At the calibration points and with a quick comparison to...
I can't see anything unusual either.
Translated on 24-07-2026, 23:10.
JohnRambo1980
Post14-07-2025, 18:24    Subject: Touareg: Intermittent Jerking - 4.2 TDI Fix Quote
Hello Rainer,
Thank you for your feedback.
Raimund
Translated on 24-07-2026, 23:11.
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg documentation, clacking sounds coming from the st... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N3, 1.4 TDI: Intermittent jerking/hesitation Diesel Engine Technology
No new posts Golf/Octavia Brake Vibration: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts 1.9 TDI AWX sporadisches Zucken im Leerlauf / Motor geht aus Diesel Engine Technology
No new posts Golf 2 TD Pöl sporadisches Nageln zw. 1200 und 1800 rpm Diesel Engine Technology
