Audi A1 Coolant Refill: 1.4 TDI Guide
Malo
Post16-07-2025, 6:14    Subject: Audi A1 Coolant Refill: 1.4 TDI Guide Quote
According to the repair manual, the coolant should be filled using a vacuum system. I bought a device from Stahlmaxx for this purpose and tested it with my small air compressor (6-liter tank) to see how much vacuum pressure I could generate. The compressor managed to create 0.6 bar of vacuum, but the pressure immediately dropped back down to 0.2 bar.
Ich dachte Kühlkreislauf hat ein Leck und habe mal mit der Handpumpe 1bar Druck auf das System gegeben. Die 1bar hat das System die ganze Nacht gehalten. So, no leak.
Does anyone know about something like this?
What other ways are there to fill the 1.4 TDI engine without introducing too many air bubbles?
I don't want to create another problem after replacing the turbocharger.
Sure, here's the translation:
"Thank you in advance..."
Translated on 29-07-2026, 3:14.
Karma: +1333 / -0   Thank you, like it!
dieselschrauber likes this.
Post16-07-2025, 7:31    Subject: Audi A1 Coolant Refill: 1.4 TDI Guide Quote
Hi there,
I fill it as usual according to the old method and bleed it at the highest point, even though Mr. Audi might write something different in the owner's manual. Perhaps that could also work with the 1.4 TDI engine.
Translated on 29-07-2026, 3:16.
Post16-07-2025, 8:20    Subject: Audi A1 Coolant Refill: How To & Guide Quote
Seals can behave in completely different ways under pressure and vacuum conditions, and are often designed based on the direction of the pressure gradient.
Translated on 29-07-2026, 3:17.
Malo
Post17-07-2025, 21:44    Subject: Audi A1 Coolant Refill: 1.4 TDI Guide Quote
"These are often designed based on the direction of the pressure gradient."
Then I would wonder why one should fill it with vacuum pressure according to the repair instructions.
Translated on 29-07-2026, 3:19.
Post17-07-2025, 22:07    Subject: Audi A1 Coolant Refill: 1.4 TDI Guide Quote
Malo wrote:
"These are often also designed based on the direction of the pressure gradient."
Then I would wonder why one should fill it with vacuum according to the repair instructions.
I'll leave that to your imagination.
The cooling system needs to be largely free of air, as Herbert wrote.
It must be airtight and not leak any coolant.
What do you think is missing?
Translated on 29-07-2026, 3:20.
Malo
Post18-07-2025, 6:35    Subject: Audi A1 Coolant Refill: 1.4 TDI Guide Quote
"What do you think is missing?"
Please provide the text you would like me to translate from German to English. I will then give you only the translation, without any explanations.
Translated on 29-07-2026, 3:21.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi C4 2.5 TDI - Transmission oil in coolant Diesel Engine Technology
No new posts Öl im Kühlwasser Diesel Engine Technology
No new posts Kühlwasser thermostat ?? Diesel Engine Technology
No new posts Öl im Kühlwasser beim B4 mit 1Z Diesel Engine Technology
