Error log entries despite normal function
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Wumbo4711
2023 Audi A5
Post01-06-2026, 9:31    Subject: Error log entries despite normal function Quote
Hello everyone,
I have also repeatedly encountered the following errors even after clearing the fault memory in Autoscan, although there were no functional issues.
Do you have any tips for me on how to identify the root causes?
131687 - Control unit for emergency call module and communication unit
U1421 00 [00001000] - No communication
[Timeout_Node_0x67_DiagAdress_0075_ConBox]
Sporadisch - bestätigt - geprüft seit letzter Löschung
Environmental Conditions:
Error Priority: 4
Frequency of Errors: 1
Lost Count: 249
Mileage: 29627 km
Date: 2026.05.30
Time: 18:23:09
131830 - Ethernet Emergency Module
U1642 00 [00001000] - No communication
[Timeout_Node_0xF6_conBox_DiagAdress_0075]
Error Priority: 4
Lost Count: 249
Mileage: 29627 km
Date: 2026.05.30
Time: 18:20:28
262727 - Function restriction due to missing message
U1111 00 [00001001] - -
[BAP_Timeout_ConnectionManager]
Confirmed - Verified since last deletion
Error Priority: 6
Frequency of Errors: 2
Lost Count: 209
Odometer: 29625 km
Date: 2026.05.30
Time: 18:15:24
Also, the microphone error also reappears after deleting, even though the hands-free function is working perfectly.
Address A6: Microphone (J886) Label file: .420-907-394.clb
Part Number SW: 420 907 394 B HW: 420 907 394
Part: BELTMICBOX H10 0840
Encoding: 0101040202
Operating Number: WSC 02664 785 00200
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 186D1E49321E7F6A563-804C
1 Error found:
0128 - Telephone Microphone
B1048 13 [00001001] - Interrupt
Error Priority: 4
Lost Count: 208
Odometer: 29625 km
Date: 2026.05.30
Time: 18:14:51
Log-WAUZZZF56PN008263-29630km-nach probefahrt und-ahk codieren.txt
 File name:  Log-WAUZZZF56PN008263-29630km-nach probefahrt und-ahk codieren.txt
 File size:  28.34 KB
 Downloaded:  120 times
Beste Grüße,
Tobi
Post01-06-2026, 10:12    Subject: Error log entries despite normal function Quote
In your customer account, VCDS 26.3 is available for download. There may also be new labels for your control units included.
But it has nothing to do with the problem. If the control units are responsive and functioning during the vehicle scan, the problem could also be caused by software errors in the control units, in addition to wiring problems.
The microphone issue appears to be due to a real physical connection problem (cable, connector, or the microphone itself).
If everything works as intended, I would first clear all the errors and then see what happens. Often, throughout the vehicle's lifespan, software updates are available to fix minor issues.
Therefore, I wouldn't get worked up about it right now.
Best regards, Rainer
dieselschrauber likes this.
Post01-06-2026, 10:30    Subject: Error log entries despite normal function Quote
I have absolutely no knowledge of the R8. Therefore, I can only make guesses. Maybe it will still help.
According to online sources, the "Beltmicbox" module is supposed to have three microphones per belt. The cables are woven into the belt. Probably very thin. Have you ever used the microphone on the ceiling and the two belt microphones when making phone calls to check if each one works? I suspect a single defect that is compensated for by the remaining microphones. Maybe we'll switch completely to the ceiling microphone.
I suspect that there is a broken cable somewhere in the strap. However, you will only be able to replace it completely with a new strap. So, entweder man mit dem Fehler leben muss, oder man kauft einen neuen Gurt.
And regarding the emergency call module, I would either suspect a defect in the module itself, or possibly a subsequent error with the microphone. The microphone harnesses were likely a relatively rare extra (especially for a car that was already relatively rare). Therefore, the question is how extensively the emergency call module has been tested for errors in these additional microphones.
Here's some more information about coding etc. Maybe this will help you: https://www.r8talk.com/threads/seat-belt-mic-stopped-working.141369
Wumbo4711
2023 Audi A5
Post06-06-2026, 16:23    Subject: Error log entries despite normal function Quote
dieselschrauber wrote:
VCDS version 26.3 is available for download in the customer account; it may contain new labels for your control units.
The microphone issue appears to be caused by a loose connection, possibly in the cable, connector, or the microphone itself.
Hello Rainer,
Thank you for the feedback. The update didn't change anything, and the errors are still appearing even after deleting files.
Since the car has to go to the workshop anyway for other issues, I included the error codes in the description. Hopefully, it should be covered by the extended warranty.
I'm entering whatever Audi reports.
Beste Grüße,
Tobi
Wumbo4711
2023 Audi A5
Post06-06-2026, 16:25    Subject: Error log entries despite normal function Quote
guste100 wrote:
I don't know anything about the R8 at all.
Hello Guste100,
Thank you for the feedback, but I think there might be a misunderstanding. It's a normal A5 convertible, not an R8. icon_biggrin.gif
Beste Grüße,
Tobi
Post08-06-2026, 8:21    Subject: Error log entries despite normal function Quote
Wumbo4711 wrote:
Oops... I guess I got misled by the search results and ended up looking at lapel microphones instead. The rest of my statements probably also apply to your A5.
Since he already needs to take it to the workshop, I wouldn't add any more work to it at this point, but rather have them take care of it. However, workshops are often less proactive when it comes to error code entries compared to when there are noticeable functional limitations. Therefore, the micro-test might still be useful. They are more likely to take action if you can say that all or some of the seatbelt microphones are not working. Otherwise, they might give you the same response as you: "The hands-free system works fine." "So, everything is working."
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Exhaust gas recirculation: function and problem areas Technical Articles
No new posts Parking Assist Fails: No Function with New Sensor Electrical Systems, Vehicle Electronics, Multimedia
No new posts Notlauf - 2 Fehlerspeichereinträge - TDI mit AFN-Motor On-Board Diagnostics (OBD)
No new posts Mein TDi rust bei normaler fahrt???? Diesel Engine Technology
No new posts 4 nozzles with NHG instead of 3 standard nozzles Diesel Engine Technology
