Touran 1T - does not start, No 15 terminal
VAG
Karma: +9 / -0   Thank you, like it!
Post18-09-2025, 16:09    Subject: Touran 1T - does not start, No 15 terminal Quote
Hello everyone,
My Touran 1T1 (1.9 TDI BLS, year 2009, ~191,700 km) no longer starts.
Maybe someone knows about this problem.
Symptoms:
• Yesterday evening, it was still running, but this morning it wouldn't start (the battery was probably completely drained (5.4 V)). After ADAC assistance, I drove home for about 40 minutes, and the battery was fully charged again.
• To check for the cause of the leakage current, I removed all fuses and measured between the battery's negative terminal and the ground cable (no anomalies detected). After that, almost nothing happened anymore…
• Control lights on the instrument panel remain off even with the ignition on. Other consumers, such as Radio, lights, window controls, and the wireless security system are all functioning.
• Various control units are no longer accessible via VCDS.
• Relay 643 (J682, Terminal 15?) and Relay 460 (Terminal 75) both click when the start attempt is made.
• I don't know if it has something to do with this, but: In February, the steering wheel warning light blinked at the same rhythm for a few days and then disappeared…
• Previously reviewed:
• All fuses are OK (visually & continuity)
• Safety clip (1K0 937 629A) tested with fuse clips ▔ 12 V at all outputs.
• Replaced starter motor (1K0953503) → no change.
• Charge both batteries again and install them alternately. Also, additional starting assistance provided: No change.
I have attached a log from 26.08.2025 and one from today. I even obtained the circuit diagrams (over 2700 pages icon_sad.gif).
If anyone could offer me some assistance here, that would be fantastic! However, with so many errors, I don't even know where to start icon_evil.gif
Log-BK136-WVGZZZ1TZ9W104333-191760km.txt
 File name:  Log-BK136-WVGZZZ1TZ9W104333-191760km.txt
 File size:  16.96 KB
 Downloaded:  207 times
Log-WVGZZZ1TZ9W104333-191200km.txt
 File name:  Log-WVGZZZ1TZ9W104333-191200km.txt
 File size:  13.54 KB
brezelmann01
Karma: +75 / -0   Thank you, like it!
dieselschrauber and Herbert likes this.
Post19-09-2025, 7:36    Subject: Touran 1T - does not start, No 15 terminal Quote
Hi!
Please turn the vehicle off completely for another 10 minutes. Main fuses (strip fuses) also checked?
Basically, I would start by investigating why the 09 model is reporting an error for a missing terminal 15 in the interior...
Best regards
brezelmann01
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post19-09-2025, 8:38    Subject: Touran 1T - does not start, No 15 terminal Quote
and then in all STGs, delete the error entries relating to "low voltage".
What I notice:
- "Diagnosis interface incorrectly coded" error - how did this happen? The error can block a lot of interaction, and should be fixed urgently.
- km- Stand: at the beginning of the car scan is 191760. However, some STG´s (Central Electrical, Comfort System) show 191767. The distance traveled counter is located in the instrument panel, and the status is transmitted to the other STG's.
- Communication is lacking not only with the VCDS, but also between STGs. The status changes during the scan. Is there an improperly installed interface behind it?
Post19-09-2025, 11:44    Subject: Touran 1T - does not start, No 15 terminal Quote
After 49km, a deeply discharged battery is not fully recharged.
24 hours with a good charger and power are needed or replace it immediately.
VAG
Post19-09-2025, 18:51    Subject: Touran 1T - does not start, No 15 terminal Quote
brezelmann01 wrote:
Hi!
Best regards
brezelmann01
- I have re-thoroughly disconnected the vehicle.
- I re-checked the main/fuse box in the engine compartment, using a multimeter and even a 100-watt light bulb.
- I'm not quite sure yet where/how to start my search for the missing clamp 15. I'm currently overwhelmed by the electrical diagrams.
Below is a current error scan from today.
Log 19.09.2025.txt
 File name:  Log 19.09.2025.txt
 File size:  33.92 KB
 Downloaded:  206 times
VAG
Post19-09-2025, 18:59    Subject: Touran 1T - does not start, No 15 terminal Quote
What I notice:
- Can the diagnostic interface code itself automatically - I haven't done anything? Or, how can I properly encode it?
- These could be residual KM stands, where the control units were accessible before the connection(s) was/were interrupted.
- Meint "Interface" das Diagnoseinterface (Steuergerät 19) oder mein VCDS-Stecker? Ich habe immer die VCDS-Updates installiert, wenn das System mich dazu aufgefordert hat. I wouldn't know whether or not I could make mistakes there.
VAG
Post19-09-2025, 19:06    Subject: Touran 1T - does not start, No 15 terminal Quote
Rüdi wrote:
After 49km, a deeply discharged battery will not be fully charged.
24 hours with a reliable charger and power are needed or you'll need a new one
- I of course did that + I also gave it the full starter kit. Let's double-check for safety today.
VAG
dieselschrauber and brezelmann01 likes this.
Post20-09-2025, 15:47    Subject: Touran 1T - does not start, No 15 terminal Quote
I have apparently found the error. I must have removed and tested the fuses in the engine compartment and, in the process, not put the fuse (F7) back in its correct location. However, I did check this, but: According to the original wiring diagrams, this fuse was actually only "active" from May 2009 onwards. However, my Touran has a production date of April 2009, which is why I didn't notice it.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is the entire driver's side door electrics not working on... Transmission, Chassis, Body & Interior
No new posts Audi Q7: Won't Start - Troubleshooting Guide Diesel Engine Technology
No new posts Audi A6: Engine Won't Start - Troubleshooting Guide Diesel Engine Technology
No new posts BMW 1 Series Won't Start? Troubleshooting Guide. Diesel Engine Technology
