DPF Back Pressure Normal Values
Go to page: 1, 2, 3  Next
Jacomo83 likes this.
Post26-10-2010, 9:14    Subject: DPF Back Pressure Normal Values Quote
To assess whether the DPF requires cleaning due to insufficient fill level or excessive back pressure, I request that users with VCDS provide the following logs/values:
- Engine code or VAG part number of the engine control unit.
- Has the engine been modified or not.
- Distance covered
- Specify ambient pressure and ambient temperature (measurement block 7 and 10 or corresponding extended measurement values).
- Full-throttle log from 1500-4000rpm from measurement block 11, 67 and 68 (or corresponding extended measurements for load, ash and differential pressure) as an unprocessed CSV
file.
Example:
[code] - BRE
- Series
- 74,000 km
- 950mBar Ambient Pressure, 5°C In-take Air Temperature
Log file as attachment
Warning:
It has been shown that with increasing temperature in the filter, the differential pressure increases. To find the maximum differential pressure, several acceleration cycles in succession may be necessary. Also, when comparing the difference values, the specific temperature of the DPF is also important. icon_idea.gif
Thank you + Regards, Rainer
Benni
Post10-11-2010, 14:55    Subject: DPF Back Pressure Normal Values Quote
Would it also be of interest to see the total mileage?
The data from my items that have been washed twice are likely not very relevant, or?
Although, it would be a nice comparison; I'll get to logging now.
Post10-11-2010, 15:27    Subject: DPF Back Pressure Normal Values Quote
I hereby declare my intention to join our family's vehicle fleet:
MJ08 BLS Series
MJ10 BMM -Series
MJ07 BMP Series
MJ07 BMR -Series (but with the fourth update already installed)
Provide data.
Post10-11-2010, 19:18    Subject: DPF Back Pressure Normal Values Quote
Benni wrote:
Wouldn't the total mileage also be of interest?
Although, that would be a nice comparison; I'll get to logging now.
Okay, correct, I forgot. But the DPFs that have been washed 2 times would also be interesting!
Post17-11-2010, 14:50    Subject: DPF Back Pressure Normal Values Quote
I have data blocks 67 and 68, which show a successful regeneration from 45% to 2.2% DPF fill level.
However, there's no mention of the RPM anywhere... and I couldn't really accelerate excessively either.
Georg_G
2012 Volkswagen Golf
Post30-12-2010, 17:56    Subject: Clean DPF: Differential Pressure Skoda Superb BSS Quote
Motor BSS, current mileage 148 tkm.
5000 km ago, the DPF was cleaned using a Kärcher and a new differential pressure sensor was installed.
Environmental conditions: -5 deg C., approximately 990 mbar absolute, DPF freshly regenerated.
Here is a log of the corresponding MWBs, full throttle from t = 20 sec to t = 42 sec in the 4th. Okay.
For those who don't want to go through the log: The max. Differential pressure is 160 mbar at 4400 rpm.
LG Georg
LOG-01-067-011-068.CSV
 File name:  LOG-01-067-011-068.CSV
 File size:  5.55 KB
 Downloaded:  8139 times
Post08-05-2011, 11:29    Subject: DPF Back Pressure Normal Values Quote
Audi A3 8PA 2.0 CR TDI 103kW
Engine code CBAB
Series
14.000km
Ambient Pressure 950mbar
Intake Air Temperature 21°C
See the difference log as presented by KDataScope.
 CBAB Differenzdruck mit KDataScope
 File size:  97.46 KB
 Viewed:  121042 times
LOG-01-471-551-7391-8261-9201-9411-9431.CSV
 Log Differenzdruck Motorkennbuchstabe CBAB
 File name:  LOG-01-471-551-7391-8261-9201-9411-9431.CSV
 File size:  11.08 KB
 Downloaded:  1778 times
servusssss
Post06-09-2011, 9:38    Subject: DPF Back Pressure Normal Values Quote
here is the log:
- Federal Republic of Germany
- with a chip
- 88,000 km
- 980mBar to 920mBar ambient pressure, temperature 28 - 25°C
- without cleaning the DPF
Here are the values at max. Differential Pressure
Loading 11%
Ash mass 32 %
Differential pressure: 391 mBar icon_eek.gif @ 3690 U/min
Attached is the Log, which was originally created for the Lambda evaluation.
With highway and uphill at the end, resulting in different environmental conditions.
SG
DieselBär30x
Avatar-DieselBär30x
Post26-10-2011, 5:54    Subject: DPF Back Pressure Normal Values Quote
Morning!
- BRT (from Sharan 7M, 2010 model)
- Series
- 61,600 km
- 948.6 mbar Ambient pressure, 9.5°C Ambient temperature, 27.0°C Inlet air temperature
- Maximum pressure difference of 260mbar at the DPF
Best regards from Munich!
LOG-01-067-068-xxx.csv
 BRT Differenzdruck-Log
 File name:  LOG-01-067-068-xxx.csv
 File size:  23.68 KB
 Downloaded:  1709 times
Baba
Registered VCDS User
Post22-04-2012, 17:59    Subject: DPF Back Pressure Normal Values Quote
hasn't been written here for a long time - but the thread makes sense...
My DPF is now reporting 61g of ash, and I'm concerned that the part won't survive the June holiday. After all, there are still 1600kg of a second dwelling attached to the Passat. "A full shutdown is absolutely out of the question!"
Here are the facts:
Engine Code BMP
not tuned
DPF mileage: approximately 155,000 km, Engine mileage: approximately 50,000 km (estimated)
Ambient pressure 969 mBar, Temperature 9.9°C, maximum pressure difference of 260mbar
The log was a bit difficult because my wife kicked me three times (despite the manual transmission and DSG).
LOG-01-067-068-xxxdpf2.CSV
 Druckdifferenz DPF am BMP Motor (Vollgas, 61g Aschemasse).
 File name:  LOG-01-067-068-xxxdpf2.CSV
 File size:  2.39 KB
 Downloaded:  1705 times
Post22-04-2012, 18:10    Subject: DPF Back Pressure Normal Values Quote
hkss
Avatar-hkss
Karma: +13 / -0   Thank you, like it!
2017 Skoda Yeti
Post14-05-2012, 18:45    Subject: DPF Back Pressure Normal Values Quote
The DPF was just regenerated during the previous trip.
This new ride was only about 10km since the regeneration.
He has been using the 22g load for a while, and I think he'll likely move up to 23 soon.
I'm curious to know if I got the 1500-4000rpm thing right, otherwise I'm happy to repeat it.
- BMM (Golf V, 2007, 2.0 TDI, 140PS)
- Series
- 73300km
- 999.6 mbar Ambient pressure
- 20.7 degrees Celsius ambient temperature.
- 23.4 degrees of suction pipe temperature
- Maximum pressure difference of 245 mbar at the DPF
LOG-01-011-067-068.CSV
 BMM (Golf V BJ.2007 2.0 TDI 140PS)
 File name:  LOG-01-011-067-068.CSV
 File size:  6.89 KB
 Downloaded:  1399 times
Post22-05-2012, 22:13    Subject: DPF Back Pressure Normal Values Quote
HI
My BLS is at the stand, engine off, 2.55 mbar differential pressure icon_exclaim.gif
Code:
22:39:52 Block 067: Particulate filter (Emissions values I)
18.0°C Temperature before the exhaust gas turbine
30.0°C Temperature in the Particle Filter
2.55 Pressure Difference Particle Filter
-5.10 Offset Difference Pressure
I believe that soon there will be two new differential pressure sensors...
Post23-05-2012, 7:58    Subject: DPF Back Pressure Normal Values Quote
dieselmartin wrote:
My BLS is in standby, engine off, 2.55 mbar differential pressure icon_exclaim.gif
I think there will soon be two new differential pressure sensors...
I would only do this if this error significantly distorts the interesting (!) values during operation.
For example, if only a 20 mbar difference in pressure occurs in a Pmax system, then an error of 2.5 mbar is already 12.5% = a significant amount.
At a Pmax pressure of 200 mbar above the cork, the error would only be 1.25% -> that's perfectly fine for me icon_wink.gif
hkss
Avatar-hkss
2017 Skoda Yeti
Post31-05-2012, 9:32    Subject: DPF Back Pressure Normal Values Quote
Here is a log of 13, 67, and 23 from the first cold start until the engine reached operating temperature.
And another log entry, with values of 67, 69, and 71, recorded during a recovery run.
LOG-01-27_067-069-071.CSV
 Regenerationsfahrt
Regenerationsfahrt
 File name:  LOG-01-27_067-069-071.CSV
 File size:  194.21 KB
 Downloaded:  1233 times
LOG-05-013-067-023.CSV
 1.Kaltstart des Tages (keine Regenerationsfahrt!)
MWB 13 -
Kanal 1 - Einspritzm.-Abw.Zylinder 1 - VC-Scope Max:2 Min:-5
Kanal 2 - Einspritzm.-Abw.Zylinder 2 - VC-Scope Max:2 Min:-5
Kanal 3 - Einspritzm.-Abw.Zylinder 3 - VC-Scope Max:2 Min:-5
Kanal 4 - Einspritzm.-Abw.Zylinder 3 - VC-Scope Max:2 Min:-5
MWB 067 -
Kanal 1 - Temperatur vor Abgasturbolader - VC-Scope Max:900 Min:0
Kanal 2 - Temperatur im Partikelfilter - VC-Scope Max:900 Min:0
Kanal 3 - Druckdifferenz Partikelfilter - VC-Scope Max:200 Min:1
Kanal 4 - Offset Differenzdruck - VC-Scope Max:1 Min:0
MWB 23 -
Kanal 1 - Schaltzeitabweich.Zylinder 1 - VC-Scope Max:3 Min:-94
Kanal 2 - Schaltzeitabweich.Zylinder 2 - VC-Scope Max:3 Min:-94
Kanal 3 - Schaltzeitabweich.Zylinder 3 - VC-Scope Max:3 Min:-94
Kanal 4 - Schaltzeitabweich.Zylinder 4 - VC-Scope Max:3 Min:-94
MWB 13 -
MWB 067 -
MWB 23 -
 File name:  LOG-05-013-067-023.CSV
 File size:  97.22 KB
 Downloaded:  1186 times
Post31-05-2012, 12:05    Subject: DPF Back Pressure Normal Values Quote
No new posts P244B - Diesel Particulate Filter - Differential Pressure... General Tips
No new posts P244B Diesel Particulate Filter Differential Pressure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure DPF vs. exhaust backpressure (and S... Diesel Engine Technology
No new posts DPF differential pressure slightly high Diesel Engine Technology
No new posts Differential Pressure & Backpressure: 3.0 TDI Comparison Diesel Engine Technology
No new posts Where is the differential pressure sensor located? Diesel Engine Technology
