Audi 100 C4: Water in A-Pillar - Fix It!
christians
Post13-12-2003, 23:31    Subject: Audi 100 C4: Water in A-Pillar - Fix It! Quote
"Water is leaking into my Audi 100 C4 from the A-pillar, specifically from a foam plug through which the cables to the driver's door pass. Of course, that plug can't be sealed properly. The question is, where does water most commonly enter the A-pillar on this model? The car does NOT have a sunroof or anything similar."
Christian.
Gruß Christian
Translated on 24-09-2026, 6:49.
mersente
Post13-02-2004, 23:48    Subject: Audi 100 C4: Water in A-Pillar - Fix It! Quote
How about the coolant reservoir (located under the windshield, behind the engine)?
Are all the processes free?
Translated on 24-09-2026, 6:50.
christians
Post14-02-2004, 2:36    Subject: Audi 100 C4: Water in A-Pillar - Fix It! Quote
Yes, if they are on, it's coming from the heating system.
I might have found the cause, but I need to observe it further to be sure.
A seal on a weld seam in the water reservoir, located between the fuse/relay box and the support bracket, had ruptured. I have resealed it and am waiting to see if the problem is resolved.
Gruß Christian
mersente
Post14-02-2004, 21:58    Subject: Audi 100 C4: Water in A-Pillar - Fix It! Quote
Yes, I'm curious to see what happens.
Translated on 24-09-2026, 6:51.
christians
Post13-04-2004, 12:57    Subject: Audi 100 C4: Water in A-Pillar - Fix It! Quote
The error has not occurred again. I wasn't entirely sure at first, but it seems there might have been some residual water leaking out.
Gruß Christian
mersente
Post13-04-2004, 22:00    Subject: Audi 100 C4: Water in A-Pillar - Fix It! Quote
No new posts Audi A3 Cracking Noise B-Pillar (8L 1996-2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4 8D, production date up to 10/1999, dents on t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Handwashing on the go, without water General Tips
No new posts Coolant temperature sensor Audi 100 C4 AAT Diesel Engine Technology
No new posts Unknown air flap on Audi 100 C4 Transmission, Chassis, Body & Interior
No new posts Turbo Upgrade Audi 100 C4 2.5 TDI AAT: Possible? Diesel Engine Technology
No new posts How do you loosen the hinge screws on the A-pillar? Transmission, Chassis, Body & Interior
