Train T90 / T 91 with VCDS (Solution)
Post12-10-2025, 15:30    Subject: Train T90 / T 91 with VCDS Quote
To connect a new T90/T91 remote control to the heater with VCDS, follow these steps:
Control unit -> 0B Air heater
Button Customization / Adaptation [10] select.
Choose Channel 5.
VCDS should now display "Learning" or "Relearn".
1. Select the value and immediately press the OFF button on the T90/T91.
Ratings - Train T90 / T 91 with VCDS
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Can TPMS sensors be programmed with VCDS? On-Board Diagnostics (OBD)
No new posts Audi R8 Gen 2 Steering Wheel Alignment with VCDS On-Board Diagnostics (OBD)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
