dieselschrauber wrote: |
Here's the translation:
"The wheel speed data, which can be accessed through the ABS/ESP system, must be reasonably consistent. The system detects differences in wheel speeds. Since this data is also needed for ABS/ESP, I advise against disabling the warning light, as a wheel speed sensor may be providing no signal or a poor signal. Also, check for large rust particles on the sensor and any damage to the wiring."
Sincerely |
Thank you, but I'll wait until the tire change for that.
It's not urgent, just annoying.
