Weini
Post25-06-2003, 9:11    Subject: { Quote
My fuel injector for my Audi 80 TDI (1Z engine) is broken (sudden jerking on the highway and black smoke...).
Does anyone know the torque with which the clamp that holds the fuel injector in the cylinder head must be tightened?
Thank you & Best regards - Weini
Update:
I just replaced the NHG. It should be done in about half an hour, if you're not as stupid as I am icon_confused.gif and you don't forget the small copper ring at the bottom of the fuel injector...
I tightened the nut with 45Nm. Although I haven't been able to determine the officially specified torque, the old nozzle tightened to approximately 45 Nm. icon_cool.gif
Post25-06-2003, 20:10    Subject: { Quote
The specification is only 20 Nm... however, I also find that to be a bit too low.
IMO, however, one should not consider the tightening torque as a torque value, because, according to experience, many screws seem to "seize" over time (even without visible corrosion), icon_question.gif icon_question.gif icon_question.gif which makes loosening considerably more difficult than tightening.
haehnlein
Post25-06-2003, 20:42    Subject: { Quote
ulf wrote:
20 Nm
edited: there was an error on my part (to prevent readers from receiving incorrect information icon_razz.gif)
____________
Kein Auto mehr!
Post26-06-2003, 8:39    Subject: { Quote
haehnlein wrote:
15 Nm according to the manufacturer's instructions icon_exclaim.gif I tightened them to 12 Nm - no problem
Hi Haehnlein
Are you sure that the nozzles are also properly sealed against the combustion chamber (e.g., oil bubble test from the nozzle replacement article)?
In fact, due to the gear ratio, only one force acts on the nozzle and therefore on the sealing ring, which is approximately half the actual clamping torque.
And that a nozzle can already seal against pressures in the order of 150 bar with a torque of just 6 Nm, is quite difficult for me to believe.
Because the sealing ring must be pressed in such a way icon_exclaim.gif that it adapts to the small irregularities and unevenness between the (possibly slightly misaligned!) nozzle and the ZK sealing surface.
And finally, there are sometimes even traces of it: I have seen, after cleaning, several times approximately radially-shaped black lines, as if soot-laden combustion gases had carved a path under the sealing ring into the soft aluminum.
For example, if you run a thin screwdriver over it, you can definitely feel the irregularities, which means the copper material has to be compressed into the nozzle during installation.
Removing the irregularities with a homemade tool took quite a while; it was estimated that about 0.2 mm had to be removed until the entire sealing surface was smooth again.
Therefore, I'd almost bet that at least not Your nozzles are really completely sealed icon_confused.gif
haehnlein
Post26-06-2003, 11:15    Subject: { Quote
Hi Ulf,
Command back icon_redface.gif icon_redface.gif icon_redface.gif My mistake, I was distracted by the light bulbs icon_redface.gif icon_redface.gif icon_redface.gif I'm an idiot icon_mad.gif Iron for injectors, of course, 20 Nm. 45 Nm is definitely too much, because it could damage the aluminum thread -> and then it becomes a problem.
____________
Kein Auto mehr!
Weini
Post26-06-2003, 11:33    Subject: { Quote
Hello again,
Thanks again for the information!! I loosened the nozzle again and tightened it with about 20Nm (using a 1/4-inch ratchet). With the large 3/4' torque wrench, even 45Nm is quite a bit, but when loosening it with the small wrench, I quickly realized that it was much too tight icon_redface.gif
Next time, it won't happen again...
Thank you & Regards - Weini
Post26-06-2003, 14:38    Subject: { Quote
Weini wrote:
I have loosened the fitting again and tightened it to approximately 20Nm
Based on my experience, this is a fairly "reliable" method for worsening the seal between the nozzle and the ZK - especially if the screw is loosened to the point that the nozzle can only be moved slightly before being re-fixed.
I would definitely perform the oil bubble test for verification purposes, and if the result indicates, I would remove the nozzle again and re-insert it with a new O-ring.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Diesel Injectors: V6 2.5L AFB Engine Repair Diesel Engine Technology
No new posts Fuel Injectors VW Golf IV AHU/ALH 90hp Diesel Engine Technology
No new posts New fuel injectors for 1Z engine Diesel Engine Technology
No new posts Audi AAT/AEL Injectors: Comparison with VW 1Z/AFN/ACV Diesel Engine Technology
