Diesel Particulate Filter Error Codes: 18434, P2002, 008194 (Solution)
Karma: +807 / -0   Thank you, like it!
Post19-07-2026, 19:18    Subject: Diesel Particulate Filter Error Codes: 18434, P2002, 008194 Quote
The error codes 18434/P2002/008194, along with P2001, are the most common DPF error codes in VAG diesel vehicles. The diesel particulate filter no longer sufficiently fulfills its cleaning function - usually because it is overloaded with ash (maximum ash masses and their adjustment) and is no longer regeneratable. This is not a defect, but wear and tear.
When is the DPF too full? Values for typical DPF ash content.
What do the error codes 18434/P2002/008194 mean?
The engine control unit monitors the differential pressure across the DPF (using sensor G450) and calculates the soot load based on this. If the soot load exceeds a threshold, regeneration is no longer possible. The filter is "full" and needs to be replaced or professionally cleaned.
Typical symptoms:
- Engine control light and/or DPF light illuminated.
- The motor is running in emergency mode (reduced power).
- Particulate filter warning light is flashing.
- Automatic regeneration is no longer possible.
- In extreme cases, the vehicle may not start (depending on the model year).
- Often combined with codes P2001 or P2463 (diesel particulate filter soot accumulation).
Most common causes:
- The DPF has excessive ash buildup (normal wear and tear after 150,000-250,000 km).
- Frequent short trips: Regeneration is constantly interrupted.
- EGR valve is defective or not closing properly - increases soot production.
- Intercooler or its hoses are leaking (hissing sounds, oil traces) - increases soot formation.
- Differential pressure sensor G450 is defective (reporting incorrect load values).
- Turbocharger oil leak - increased ash content.
- Injectors leaking or worn out - incomplete combustion.
Diagnosis with VCDS:
- Auto-Scan: Read P2002 code from the engine control unit.
- Measurement blocks for DPF: Ash loading (g or %), Soot loading, Differential pressure.
- Calculated soot mass: critical.
- Ash content: Filter is too full.
- Check the differential pressure of G450 (setpoint/actual value).
- Check the date and mileage of the last successful regeneration.
Repair:
- Have the DPF professionally cleaned or clean the DPF yourself - alternatively, replace the DPF, for example, in case of damage.
- Replace G450 sensor if defective.
- Force DPF emergency regeneration
Prevention:
- Driving long distances (regeneration requires approximately 20-30 minutes of uninterrupted operation).
- Use high-quality diesel fuel and the appropriate engine oil (with low ash content).
- Prevent martens from damaging the car (e.g., by chewing on the wiring for the SCR system and temperature sensors) by installing a wire mesh under the car, close to the ground.
 File size:  183.94 KB
 Viewed:  178 times
Translated on 22-11-2026, 11:22.
Ratings - Diesel Particulate Filter Error Codes: 18434, P2002, 008194
No new posts P2458 - Diesel Particulate Filter, Regeneration Duration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF & Environmental Zones: Quick FAQ Technical Articles
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts DPF problem P2002 Diesel Engine Technology
New posts DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI Diesel Engine Technology
No new posts Error code P2002 Passat 2.0 TDI BMR Diesel Engine Technology
No new posts DPF Error P2002: 3.0 TDI CCWA Fix Diesel Engine Technology
