PD Injector Data: 3-Cylinder Engine Performance (Articles)
🔗 🖨 Dieselschrauber - Index » Technical Data
dieselschrauber Post08-08-2026, 21:30
Target data for measurement blocks in 3-cylinder engines with pump-nozzle injectors (PD)
Engine codes: AMF (Lupo 3L, Audi A2 3L) and ANY (Audi A2 1.2 TDI). Engine at operating temperature (coolant temperature ≥ 80 °C). LL = idle, VL = full load, - = no specified value.
Measurement block 0 - Baseline values
FieldDescriptionAMF LLAMF VLANY LLANY VL
1Engine speed41..47134..15426..42134..154
2Start of injection117..9779..56126..11676..56
3Accelerator pedal position02550255
4Injection quantity11..37156..17511..29109..131
5Intake manifold pressure-177..21688..108161..210
6Atmospheric pressure--181..222181..222
7Coolant temperature80..3680..3680..3680..36
8Intake manifold temperature--190..51190..51
9Fuel temperature--85..17885..178
10Intake air mass60..96> 21054..87> 180
Measurement block 1 - Baseline values at idle
FieldDescriptionAMF LLANY LL
1Engine speed in RPM900..980800..880
2Injection quantity in mg/stroke3..103..8
3Delivery duration in °crank angle4..73..7
4Coolant temperature in °C80..11080..110
Measurement block 2 - Operating state at idle
2Accelerator pedal position in %00
3Operating state010010
Measurement block 3 - Air masses / EGR at idle
2Air mass setpoint in mg/stroke220..300200..270
3Actual air mass in mg/stroke200..320180..290
4EGR valve duty cycle in %30..8030..80
Measurement block 4 - Delivery start / Synchronization
1Engine speed in RPM900..9802800..3200800..8802800..3200
2Delivery start setpoint in °BTDC3..915..220..316..22
3Delivery duration setpoint in °crank angle4..717..244..615..23
4Synchronization angle in °crank angle-5..+5--3..+3-
Measurement block 5 - Starting conditions at idle
2Starting quantity in mg/stroke9..2013..18
3Start synchronization11
Measurement block 8 - Injection quantities at full load
FieldDescriptionAMF VLANY VL
1Engine speed in RPM2800..32002800..3200
2Injection quantity, driver demand in mg/stroke50..6545..51
3Torque limitation in mg/stroke43..4831..36
4Smoke limitation in mg/stroke46..5529..40
Measurement block 10 - Full load boost pressure
1Actual air mass in mg/stroke> 700> 600
2Atmospheric pressure in mbar-900..1100
3Intake manifold pressure in mbar1800..22001650..2140
4Accelerator pedal position in %100100
Measurement block 11 - Boost pressure control
2Boost pressure setpoint in mbar900..11001800..2100900..11001650..2100
3Actual boost pressure in mbar900..11001800..2100900..11001650..2140
4Boost pressure valve duty cycle in %25..9540..9525..9540..95
Measurement block 13 - Smooth running control at idle
1Smooth running regulator cylinder 1 in mg/stroke-2,8..+2,8-1,9..+ 1,9
2Smooth running regulator cylinder 2 in mg/stroke-2,8..+2,8-1,9..+ 1,9
3Smooth running regulator cylinder 3 in mg/stroke-2,8..+2,8-1,9..+ 1,9
Measurement block 18 - PD element status at idle
1PD element 1 status00
2PD element 2 status00
3PD element 3 status00
Source: community.dieselschrauber.org – Michael II
Translated on 09-08-2026, 11:07.
Ratings - PD Injector Data: 3-Cylinder Engine Performance
New posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
New posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
New posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Solldaten der Messwertblöcke anders ??? Diesel Engine Technology
No new posts Solldaten MKB AFB Diesel Engine Technology
No new posts Solldaten Messwerteblock T5 AXE Diesel Engine Technology
No new posts Target data for R 32 engine, BFH On-Board Diagnostics (OBD)
