PD Injector Data: 4-Cylinder Engine Performance (Articles)
🔗 🖨 Dieselschrauber - Index » Technical Data
dieselschrauber Post08-08-2026, 22:12
Target data for measurement blocks of 4-cylinder engines with pump-nozzle injectors (PD)
Engine codes: AJM, ATJ | ATD, AXR | AVB | ASZ | AVF, AWX
Engine at operating temperature (coolant temperature ≥ 80 °C). LL = idle, VL = full load, - = no specified value.
(Manual) = manual gearbox, (Automatic) = automatic transmission, (FWD) = front-wheel drive, (AWD) = all-wheel drive
Measurement block 0 - Baseline values
MBFieldDescriptionAJM,ATJ LLAJM,ATJ VLATD,AXR LLATD,AXR VLAVB LLAVB VLASZ LLASZ VLAVF,AWX LLAVF,AWX VL
01Engine speed43..39150..13641..45 (manual) 38..42 (automatic)134..15436..42 (FWD) 41..46 (AWD)136..15041..45 (manual) 38..42 (automatic)134..15436..42 (FWD) 41..46 (AWD)136..150
2Start of injection124..13453..63113..13376..47120..13255..76113..13360..85113..13360..85
3Accelerator pedal position02550255025502550255
4Injection quantity11..40160..17211..33142..16411..33142..15311..33171..21911..33171..219
5Intake manifold pressure108..90245..197-181..22189..112187..211-206..25588..113206..255
6Atmospheric pressure223..183223..183--183..223183..223--181..222183..223
7Coolant temperature80..3580..3588..3688..3680..3580..3588..36< 8080..3580..35
8Intake manifold temperature189..51189..51--51..18951..189--51..18951..189
9Fuel temperature170..85201..85--85..17085..201--85..17085..201
10Intake air mass70..126245..25560..111> 24070..126> 24063..105> 24563..105> 255
Measurement block 1 - Baseline values at idle
11Engine speed in RPM830..900860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)
2Injection quantity in mg/stroke3..113..93..93..133..9
3Delivery duration in °crank angle5..73..85..83..83..8
4Coolant temperature in °C80..11080..11080..11080..11080..110
Measurement block 2 - Operating state at idle
21Engine speed in RPM830..900860..940 (manual) 790..870 (automatic)36..42 (FWD) 41..46 (AWD)860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)
2Accelerator pedal position in %00000
3Operating state010010010010010
Measurement block 3 - Air masses / EGR at idle
31Engine speed in RPM830..900860..940 (manual) 790..870 (automatic)36..42 (FWD) 41..46 (AWD)860..940 (manual) 790..870 (automatic)790..870 (FWD) 860..945 (AWD)
2Air mass setpoint in mg/stroke230..420220..350230..420230..310230..310
3Actual air mass in mg/stroke230..420200..370210..420210..350210..350
4EGR valve duty cycle in %10..95-50..70-40..75
Measurement block 4 - Delivery start / Synchronization
41Engine speed in RPM830..9002850..3150860..940 (manual) 790..870 (automatic)2800..320036..42 (FWD) 41..46 (AWD)2850..3150860..940 (manual) 790..870 (automatic)2800..3200790..870 (FWD) 860..945 (AWD)2850..3150
2Delivery start setpoint1°BTDC..2°ATDC20°BTDC..23°BTDC4°BTDC..2°ATDC-16°..-25°crank angle2°BTDC..2°ATDC16°..22.5°BTDC4°BTDC..2.5°ATDC13..23°BTDC4°BTDC..2°ATDC13..21°BTDC
3Delivery duration setpoint in °crank angle5..720..233..819..245..819..22.53..816..283..816..28
4Synchronization angle in °crank angle-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3-3..+ 3
Measurement block 8 - Injection quantities at full load
81Engine speed in RPM2850..31502800..32002850..31502800..32002850..3150
2Injection quantity, driver demand in mg/stroke50..5542..5242..5065..7065..70
3Torque limitation in mg/stroke44..4725..4739..4225..5147..51
4Smoke limitation in mg/stroke47..5216..3648..5216..5547..60
Measurement block 10 - Full load boost pressure
101Actual air mass in mg/stroke850..1050200..370800..1100800..1100210..350900..1250900..1250
2Atmospheric pressure in mbar910..1110--910..1110--910..1110
3Intake manifold pressure in mbar2000..2200--1900..2150-2100..26002100..2600
4Accelerator pedal position in %100-100100-100100
Measurement block 11 - Boost pressure control
111Engine speed in RPM2850..31502800..32002850..31502800..3200
2Boost pressure setpoint in mbar2000..21501900..21001900..21502200..2400
3Actual boost pressure in mbar2000..22001850..22501900..21502100..2600
4Boost pressure valve duty cycle in %45..9545..8055..7540..95
Measurement block 13 - Smooth running control at idle
131Smooth running regulator cylinder 1 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
2Smooth running regulator cylinder 2 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
3Smooth running regulator cylinder 3 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
4Smooth running regulator cylinder 4 in mg/stroke-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8-2,8..+ 2,8
Measurement block 18 - PD element status at idle
181PD element 1 status00000
2PD element 2 status00000
3PD element 3 status00000
4PD element 4 status00000
Source: community.dieselschrauber.org – Michael II
Translated on 09-08-2026, 11:24.
Ratings - PD Injector Data: 4-Cylinder Engine Performance
New posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
New posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
New posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts Solldaten der Messwertblöcke anders ??? Diesel Engine Technology
No new posts Solldaten MKB AFB Diesel Engine Technology
No new posts Solldaten Messwerteblock T5 AXE Diesel Engine Technology
No new posts Target data for R 32 engine, BFH On-Board Diagnostics (OBD)
