VE Injection Pump Data: 4-Cylinder Engine Performance (Articles)
🔗 🖨 Dieselschrauber - Index » Technical Data
dieselschrauber Post08-08-2026, 22:15
Target data for measurement blocks of 4-cylinder VE engines (distributor injection pump)
Engine codes: 1Z, AHU | AEY | AFN, AVG | AGP, AQM | AHF, ASV | ALE | ALH, AGR
Engine at operating temperature (coolant temperature ≥ 80 °C). LL = idle, VL = full load, - = no specified value.
Measurement block 0 - Baseline values
MBFDescription1Z,AHU LL1Z,AHU VLAEY LLAEY VLAFN,AVG LLAFN,AVG VLAGP,AQM LLAGP,AQM VLAHF,ASV LLAHF,ASV VLALE LLALE VLALH,AGR LLALH,AGR VL
01Engine speed41..45136..15041..45136..15041..45136..15041..46138..14841..46138..14841..45134..15341..46138..148
2Start of injection0..88138..1880..88120..1600..88138..18825..125113..16312..75137..21512..75137..21312..75137..215
3Accelerator pedal position0255025502550255025502550255
4Injection quantity11..45175..17811..45100..13011..45192..21511..45125..14011..45199..21411..45170..19011..45199..214
5Intake manifold pressure-209..238 (00011) 155..189 (00012)---180..245--83..106179..215-163..22583..106179..215
6Atmospheric pressure------181..222181..222183..224183..224--183..224183..224
7Coolant temperature80..3580..3580..3580..3580..3580..3580..3580..3580..3580..3580..3580..3580..3580..35
8Intake manifold temperature80..18280..18280..18250..18250..18250..18250..18250..18250..18250..18280..19035..19050..18250..182
9Fuel temperature91..20191..20191..20191..20191..20191..20191..20191..20191..20191..20191..20191..20191..20131..201
10Intake air mass84..128 (00011) 69..111 (00012)225..25569..22569..22569..135225..255--69..11125569..11125569..111255
Measurement block 1 - Baseline values at idle
11Engine speed in RPM861..945861..945861..945861..945861..945861..945861..945
2Injection quantity in mg/stroke2.2..92.2..92.2..92.2..92.2..92.2..92.2..9
3Control slide voltage in V1.25..1.71.4..1.81.46..1.91.6..2.11.3..2.11.35..2.11.3..2.1
4Coolant temperature in °C80..11080..11080..11080..11080..11080..11080..110
Measurement block 2 - Operating state at idle
21Engine speed in RPM861..945861..945861..945861..945861..945861..945861..945
2Accelerator pedal position in %0000000
3Operating state010010010010010010010
Measurement block 3 - Air masses / EGR at idle
31Engine speed in RPM861..945861..945861..945861..945861..945861..945861..945
2Air mass setpoint in mg/stroke230..420-230..450230..370230..370240..340230..370
3Actual air mass in mg/stroke280..420 (00011) 230..370 (00012)246..750230..450230..370230..370240..340230..370
4EGR valve duty cycle in %10..9090..9810..9094..9640..7540..8440..75
Measurement block 4 - Start of injection
41Engine speed in RPM861..9452850..3150861..9452850..3150861..9452850..3150861..9452900..3100861..9452900..3100861..9452800..3200861..9452900..3100
2Start of injection setpoint3°ATDC..4°BTDC8..12°BTDC0..5°BTDC6..10°BTDC2°ATDC..4°BTDC8..12°BTDC1°ATDC..7°BTDC6..10°BTDC2°ATDC..3°BTDC8..14°BTDC2°ATDC..3°BTDC8..14°BTDC2°ATDC..3°BTDC8..14°BTDC
3Actual start of injection3°ATDC..4°BTDC8..12°BTDC0..5°BTDC6..10°BTDC2°ATDC..4°BTDC8..12°BTDC1°ATDC..7°BTDC6..10°BTDC2°ATDC..3°BTDC8..14°BTDC2°ATDC..3°BTDC8..14°BTDC2°ATDC..3°BTDC8..14°BTDC
4Injection start valve duty cycle2..1060..9010..6060..902..9560..982..8070..953..8050..953..7050..953..8050..95
Measurement block 8 - Injection quantities at full load
81Engine speed in RPM2850..31502850..31502850..31502900..31002900..31002800..32002900..3100
2Injection quantity, driver demand in mg/stroke36..4223.2..24.643..4541..4542..4638..4538..42
3Torque limitation in mg/stroke34.2..35.224..2540..4226..2838.2..42.234..3934.2..38.2
4Smoke limitation in mg/stroke35..3820..2638.5..4425..3041..4432..4037..40
Measurement block 10 - Full load boost pressure
101Actual air mass in mg/stroke750..850850..1050800..1100750..1100800..1100
2Atmospheric pressure in mbar--900..1100-900..1100
3Intake manifold pressure in mbar1750..19501700..22501850..22501700..22501850..2250
4Accelerator pedal position in %100100100100100
Measurement block 11 - Boost pressure control
111Engine speed in RPM2850..31502850..31502850..31502900..31002800..32002900..3100
2Boost pressure setpoint in mbar1720..1950-1900..20001850..19501850..19501850..1950
3Actual boost pressure in mbar1720..1950-1700..25001850..22501700..22501850..2250
4Boost pressure valve duty cycle in %40..7094..9645..9445..9545..9545..95
Measurement block 13 - Smooth running control at idle
131Cylinder 1---Smooth running regulator cylinder 1 -1.9..+ 1.9 mg/stroke-2.0..+ 2.0--2.0..+ 2.0
2Cylinder 2---Smooth running regulator cylinder 2 -1.9..+ 1.9 mg/stroke-2.0..+ 2.0--2.0..+ 2.0
3Cylinder 4---Smooth running regulator cylinder 3 -1.9..+ 1.9 mg/stroke-2.0..+ 2.0--2.0..+ 2.0
4Cylinder 4 (AGP/AHF/ALH)---Smooth running regulator cylinder 4 -1.9..+ 1.9 mg/stroke-2.0..+ 2.0-2.0..+ 2.0
Measurement block 19 - Control slide travel (AGP, AHF, ALH)
191Control slide travel voltage at start in V0.500..0.9700.500..0.9700.500..0.970
2Control slide travel voltage at stop in V4.150..4.7404.150..4.7404.150..4.740
Source: community.dieselschrauber.org – Michael II
Translated on 08-08-2026, 23:08.
Ratings - VE Injection Pump Data: 4-Cylinder Engine Performance
New posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
New posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
New posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts Solldaten der Messwertblöcke anders ??? Diesel Engine Technology
No new posts Solldaten MKB AFB Diesel Engine Technology
No new posts Solldaten Messwerteblock T5 AXE Diesel Engine Technology
No new posts Target data for R 32 engine, BFH On-Board Diagnostics (OBD)
