T4 AJT ESP Issues: Troubleshooting & Solutions
Go to page: 1, 2  Next
Erikmar
Post12-08-2026, 11:49    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
"Hi, I have a VW T4 Caravelle from 2002 with the AJT 2.5 TDI engine. My problem is that the car was heavily smoking black during driving and then stalled. Since then, it hasn't started properly. I've been able to pinpoint the source of the problem to the mass airflow sensor. Here's my issue: I can see the target value in function block 02 and observe how it changes when I adjust things. In function block 019, which shows the initial values, I should have 1 volt and 5 volts, but instead, I only get 1 volt on both readings. VCDS reported an error code: "mass airflow sensor - lower limit."
Can someone help me with this?
Translated on 12-08-2026, 11:50.
Post12-08-2026, 12:04    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Translating...
[Translating...]
Autoscan?
Erikmar
Post12-08-2026, 12:27    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
I'll send it over later.
Translated on 12-08-2026, 12:27.
Erikmar
Post12-08-2026, 12:58    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
It's not showing me any errors right now.
 File size:  5.98 MB
 Viewed:  106 times
pic-3908334926a7c51cb43a31-b4XuGx
 File size:  3.52 KB
 Viewed:  101 times
Translated on 12-08-2026, 12:59.
Erikmar
Post12-08-2026, 15:05    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Okay, all the measurements are within acceptable limits except between values of 3 and 5, or 6 and 7, where there is no resistance detected.
 File size:  5.91 MB
 Viewed:  87 times
 File size:  6.4 MB
 Viewed:  87 times
Translated on 12-08-2026, 15:06.
Erikmar
Post12-08-2026, 15:19    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Okay, yes, that's right. And before I forget, the anchor switch – specifically, the quantity selector – isn't working at all; it doesn't engage or disengage when you turn the ignition on.
Translated on 12-08-2026, 15:20.
dieselschrauber likes this.
Post12-08-2026, 15:21    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
"Someone is objecting to the automatic scanning."
Does "no resistance" mean a measured value of R = infinity or R = 0?
"hg"
Translated on 12-08-2026, 15:22.
Erikmar
Post12-08-2026, 15:23    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
In my case, "no resistance" means an infinitely high resistance.
I'm sorry, I could have described that better.
Translated on 12-08-2026, 15:23.
Post12-08-2026, 15:34    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Okay.
Translated on 12-08-2026, 15:34.
Erikmar
Post12-08-2026, 15:36    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Okay, and why doesn't the slider perform a reference run when starting? And how are the values "1,... V" obtained in the VB 19?
Translated on 12-08-2026, 15:36.
Post12-08-2026, 16:08    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
You're reading at least 1 MΩ up there, right?
Translated on 12-08-2026, 16:09.
Erikmar
Post12-08-2026, 16:11    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Okay, that seems right, but under the measurement block "019," there's a "start" and I think a "stop" function, or something like that. The voltages have always been around 0.7V and a good 4V, but now both are showing the same value, which is about 1V.
Translated on 12-08-2026, 16:12.
Post12-08-2026, 16:53    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Okay, here's the translation:
"Now, please provide the car scan."
Translated on 12-08-2026, 16:53.
Post12-08-2026, 17:46    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Suspected cable break in the area of the starter motor.
Translated on 12-08-2026, 17:46.
Erikmar
Post12-08-2026, 18:47    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Hi.
Okay, so the explanation for why the FB 019 values were at 1V: There are two hidden fuses inside the unit, above the relays. One of them was blown. Since then, it's been working fine.
Translated on 12-08-2026, 18:47.
Post13-08-2026, 4:49    Subject: T4 AJT ESP Issues: Troubleshooting & Solutions Quote
Hi there,
and how did you come up with the idea of using fuses?
Translated on 13-08-2026, 4:49.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Probleme mit der ASU Diesel Engine Technology
No new posts 2.5 TDI AAT Problems: Common Issues & Fixes Diesel Engine Technology
No new posts ABS Problems: Causes and Solutions On-Board Diagnostics (OBD)
No new posts ALE: Troubleshooting GRA Issues in MKB Diesel Engine Technology
