DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI
mxamillion
Post21-11-2026, 23:36    Subject: DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI Quote
Hello everyone,
ich fahre einen Touareg 7L 2.5 TDI mit dem Motorkennbuchstaben BPE, Automatikgetriebe, Laufleistung ca. 254.000. Im Sommer 2026 aus 1. Hand-bought.
While on vacation in Sardinia, a heat shield on the exhaust side of the engine, near the DPF, partially ignited and was smoldering during a steep, approximately 15-minute uphill drive.
After that, the following errors occurred in the following order:
- Engine control light, implausible values detected by the differential pressure sensor.
- Diesel particulate filter symbol.
- Candle icon, blinking.
The engine continued to run perfectly, but a manual regeneration cycle, as described in the manual, did not resolve the issue. The return journey of approximately 1700 km had to be undertaken, but was also completed without any problems.
In the meantime, I've acquired VCDS, replaced the differential pressure sensor, and calibrated it according to the instructions, and I've also taken it for a few high-speed drives (a roof tent was previously mounted). Unfortunately, it still hasn't achieved successful regeneration.
The remaining error code is P2002: Particle Filter Bank 1 Malfunction. This error appears when the ignition is turned on and cannot be cleared.
The previous owner informed me about the following exhaust-related repairs that were carried out at a VW workshop:
- New turbocharger (1-2 years old).
- New DPF (early 2026, upon request, I was informed that it is not an original replacement part, approximately 1,800 was charged).
I have attached a recent vehicle scan, a report of static readings that show the DPF filter's condition, and a log file from a test drive.
I'm a bit lost and have a few questions to start with:
- What is still causing the P2002 error? Is it the high oxygen level, currently around 60%?
- What is the threshold for the residual sugar content beyond which regeneration is no longer feasible? I find different figures (45 vs. 90 g/%).
- If the Russian standard exceeds 45 g/%, is a (forced) regeneration possible? If the P2002 error cannot be cleared, how is this regeneration performed? In this forum, I only found information related to disconnecting a temperature sensor.
- What measurement blocks should I ideally record in order to further investigate the cause?
Thank you very much, and best regards.
Max.
 File size:  286 KB
 Viewed:  109 times
logfahrt-067-071-073-20261121.txt
 File name:  logfahrt-067-071-073-20261121.txt
 File size:  1.75 MB
 Downloaded:  24 times
messwerte-snapshot-20261121.txt
 File name:  messwerte-snapshot-20261121.txt
 File size:  715 Bytes
 Downloaded:  22 times
autoscan-20261121.txt
 File name:  autoscan-20261121.txt
 File size:  9.43 KB
 Downloaded:  23 times
Translated on 21-11-2026, 23:41.
Karma: +806 / -0   Thank you, like it!
Post22-11-2026, 11:13    Subject: DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI Quote
Based on the values shown in the image, the differential pressure is relatively high, which suggests a significant amount of ash/soot in the DPF or damage to the DPF (possibly melted and partially blocked?).
Is the correct DPF installed for this engine, meaning one that is specifically designed for this engine, or just one that fits mechanically?
Then I would also check if the engine is producing excessive soot or oil smoke, which could be constantly overfilling the DPF.
Check if the measured air mass values are plausible under load (the easiest way is to compare them with a similar engine).
High mass airflow (MAF) sensor readings under load (e.g., >1100mg/H) can indicate leaks in the charge air system. Air escapes, and is not available for combustion, leading to excessive soot.
I would inspect the entire charge air cooler system, including all the hoses and the intercooler itself, for oil traces (which are normally caused by crankcase ventilation, but can indicate leaks).
P2002:
https://community.dieselschrauber.org/en/viewtopic.php?t=31993
Good luck, Rainer.
Translated on 22-11-2026, 11:16.
mxamillion
Post22-11-2026, 21:18    Subject: DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI Quote
Hello Rainer,
Thank you for your reply.
I was only able to perform a visual inspection of the charge air path earlier, due to lack of time, and I could only do it from above in the engine compartment, up to the charge air cooler.
The only noticeable thing was that both the fresh air intake and the exhaust ports on the turbocharger were slightly oily at the clamps/hoses.
Contrary to my initial post earlier this year, the turbocharger was replaced along with the diesel particulate filter.
I need to check which specific diesel particulate filter was installed.
Furthermore, I conducted a small measurement run and recorded the data from measurement blocks 003, 010, and 011.
"Under full load, the charge air mass is likely temporarily greater than 1100 mg/H. What's noticeable to me, as a non-expert, is that the actual charge air mass (except under full load) is above the target value, and that the EGR duty cycle is constantly at 100.6%."
Does this indicate a permanently closed and therefore defective EGR valve?
Regarding the post you linked to:
- Because a new DPF has not yet accumulated a significant amount of ash, it is less likely to fail due to excessive ash buildup.
- Short distances: Possible for approximately 7 months between DPF replacements and the previous owner's sale, since then mostly long distances.
- AGR valve: possible defect (see above).
- Differential pressure sensor already replaced.
I will be inspecting the additional intercooler piping and turbocharger hose connections in the coming days.
Do you sometimes have to replace a new DPF filter again if the soot level is too high and therefore cannot be regenerated? Or are 60% still within the acceptable range according to VCDS?
 File size:  410.78 KB
 Viewed:  63 times
logfahrt-003-010-011-20261122.txt
 File name:  logfahrt-003-010-011-20261122.txt
 File size:  686.24 KB
 Downloaded:  20 times
Translated on 22-11-2026, 21:22.
Karma: +1355 / -0   Thank you, like it!
dieselschrauber likes this.
Post23-11-2026, 6:36    Subject: DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI Quote
Your measurement data snapshot is a bit confusing, as if it was taken from the English-speaking section at the end of the list. Please post a Screenshot of the extended measurement data from the engine control unit (as a CSV file).
Translated on 23-11-2026, 6:36.
Post23-11-2026, 9:30    Subject: DPF Failure P2002: Volkswagen Touareg 7L 2.5 TDI Quote
Here's another note about logs:
https://community.dieselschrauber.org/en/viewtopic.php?t=12979
INDICATES that the actual value of the charge air mass (except at full load) is above the TARGET value, and that the EGR duty cycle is constantly at 100.6 %
In partial load operation, and especially in idle conditions, the actual value should be approximately equal to the target value. Also, the EGR control rate should be constantly changing in this mode.
The % value displayed for the AGR (Abgasrückführung) control rate (which is sometimes inverted in certain engine control units) of always 100.6%, even at partial load, would either always indicate "always on" or always indicate "always off."
That would be a strong indication of a faulty EGR valve, or (if the EGR is always at its maximum) a larger leak in the charge air system (the target boost pressure is being reached, so the leak can't be that big if it's present at all), or within the EGR system itself.
Translated on 23-11-2026, 9:32.
No new posts Diesel Particulate Filter Error Codes: 18434, P2002, 008194 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Variable valve timing malfunction General Tips
No new posts P0400 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF problem P2002 Diesel Engine Technology
No new posts DPF Error P2002: 3.0 TDI CCWA Fix Diesel Engine Technology
No new posts Error code P2002 Passat 2.0 TDI BMR Diesel Engine Technology
No new posts Audi A6: P2002 Error Code & Fixes Diesel Engine Technology
