Are there two-stroke diesel engines?
Avenga
Post09-07-2003, 21:58    Subject: Are there two-stroke diesel engines? Quote
icon_arrow.gif Hi, please don't ban me from the forum right away:
Okay, so we always have heated discussions about a two-stroke icon_question.gif diesel engine.
Some people believe it exists, while others firmly deny its existence.
It seems impossible to me too, but unfortunately, I'm not 100% sure! That's why I'm asking here (so that I can finally say YES or NO)!
If nobody knows the answer here, then nobody knows it anywhere else.
Markus H.
Post09-07-2003, 22:35    Subject: Are there two-stroke diesel engines? Quote
In my opinion, ship diesel engines are two-stroke engines.
garth.brooks
Post09-07-2003, 22:52    Subject: Two-stroke diesel Quote
That's a huge topic.
Okay: The largest diesel engines in the world are ship diesel engines, and they are two-stroke engines (like those made by MAN, for example).
The German Museum has something like this - 2 cubic meters of displacement per cylinder.
There are also trucks with two-stroke diesel engines, but they are not used here due to emissions regulations.
Ford collaborated with ORBITAL Motors in Australia to develop an automotive engine, but the project was abandoned due to...? Exhaust problems!
All of these diesel engines have separate lubrication systems. Okay, so with oil extraction from the engine.
Greetings.
KombiBlue
Post10-07-2003, 5:55    Subject: Are there two-stroke diesel engines? Quote
Hello, there was even a time when a 2-cylinder, 2-stroke diesel engine was used as an AIRCRAFT ENGINE!
So, I don't think I would have gotten involved in that! icon_biggrin.gificon_biggrin.gif
And by the way: Aren't all jet engines actually diesel engines?
Diesel fuel is (almost) identical to kerosene.
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Gremlin
Post10-07-2003, 6:11    Subject: Are there two-stroke diesel engines? Quote
For the sake of completeness, it should be mentioned that most large diesel engines, while operating on a two-stroke cycle, still have valves (exhaust) in the cylinder head. Furthermore, they absolutely require a scavenging blower, because it's not possible to use the crankcase (as in a motorcycle) for this purpose.
I can scan a drawing of a MAN ship diesel engine tonight; it has a stroke of 160cm and a bore of 90cm, which are still within reasonable limits (~1000kW / cylinder). icon_wink.gif
The nominal speed is 150 RPM.
a large engine would be this: icon_wink.gif
In the post-war period, Junkers even produced an aircraft engine that operated as an opposed-piston engine using a two-stroke cycle, and it was considered very efficient and reliable. The design was already tested in 1914.
http://www.ship-technology.com/contractor_images/geislinger/1_two_stroke_diesel.jpg
'weiterer input:'
'further input:'
http://www.fh-friedberg.de/users/zima/junkers.html
http://frhewww.physik.uni-freiburg.de/~jaensch/109/pic1/fm81.jpg
btw: in the USA, some trucks also use 2-stroke diesel engines. But they're all crazy there anyway http://www.howstuffworks.com/diesel-two-stroke1.htm.
it's unnecessary to mention that all of these engines are direct injection, and some are even TDI http://www.tpub.com/fireman/14104_files/image102.jpg.
CU Gremlin.
Post10-07-2003, 6:16    Subject: Are there two-stroke diesel engines? Quote
I'd also like to add something.
http://www.steamengine.com.au/ic/engines/simple_engine/diesel-2.html
Regarding the fundamental question: Yes, there are two-stroke diesel engines, and there are quite a few of them.
Thomas K.
Post10-07-2003, 12:23    Subject: Are there two-stroke diesel engines? Quote
I remember my time in the German army, specifically when I was assigned to the W15 unit. That peculiar small armored vehicle, which looks like an oversized brake shoe or wedge and is probably better known as the MTW, had a two-stroke diesel engine, but it also featured valves and a Roots blower. And that thing was incredibly fast on the highway, and it did so without a steering wheel, relying only on two brake rods.
Avenga
Post10-07-2003, 12:54    Subject: Are there two-stroke diesel engines? Quote
I'm ready to bet now.
Alois
Post10-07-2003, 13:22    Subject: Are there two-stroke diesel engines? Quote
It's quite unfair to only find out about something here and then keep the winnings from the bet for yourself. Will the people who answer questions here in the forum at least be involved? icon_wink.gif
Jürgen
Post10-07-2003, 16:33    Subject: Are there two-stroke diesel engines? Quote
Hello Kombiblue,
a turbofan engine, commonly known as a jet engine, operates in the...
Theory encompassing everything that is even remotely injectable. There have even been...
Try using coal dust. It has only one drawback: significant erosion.
to the turbine blades.
Peter 2
Post11-07-2003, 13:27    Subject: Are there two-stroke diesel engines? Quote
A beautiful sound comes from the LANZ tractor. A two-stroke engine. icon_wink.gif
Peter.
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts 2-Stroke Diesel Engines: The Sequel Diesel Engine Technology
This topic is locked, you cannot edit or reply. 2-Stroke Oil: Problems, Solutions, and Tips Diesel Engine Technology
No new posts Climatronic Compressor Cycling Every 2 Seconds (Vento 97) Transmission, Chassis, Body & Interior
No new posts Light Relay: Does it Exist? Diesel Engine Technology
